Static, volume control, radio
Posted: Sep 24, 2020 7:45 PM
by pablogringo79
Anyone know how to resolve an issue im having with my radio/cassette player? The volume knob is really staticy and the speakers go in and out of working when trying to adjust the volume.
Re: Static, volume control, radio
Posted: Sep 24, 2020 9:16 PM
by kojo96
Spray a little electronic cleaning spay into the volume control shaft, pull the knob, WD40 works too. I use a piece of a plastic straw to cover the shaft while spraying it in. Then turn knob back/forth reapetidly. That should clean it up, repeat as necessary till its working properly.
Posted: Sep 25, 2020 12:58 AM
You might have to pull the stereo out to do it well, but kojo's advice is spot on. You have something like the pic, which has some sliding contacts inside. You need to get the contact cleaner into it. Sometimes it wicks in nicely, other times you have to get it up close and personal.
Posted: May 29, 2024 6:21 PM
by sidetwo
bumping this thread because I have a very similar problem but its only only the LEFT side of the speakers (front and back). And only in 'normal' operating range for the volume knob - if I blast it both come on. I haven't yet taken out and tried cleaning the pot but wanted to read up here and see if people thought the speaker balance could also be linked to this?
Posted: May 30, 2024 12:31 PM
by Blue Shadow
If you are cleaning the volume control, clean the balance, too.
When we go into vintage stereo gear all the knobs and switches get a dose of the correct DeoxiT product cause we don't want to go in again any time soon.
Posted: May 30, 2024 7:20 PM
by sidetwo
Is there a R/L balance? I only see front/back. Either way have the DetoxIT coming and will do the best I can with that.
