'88 535is 203k in SoCal
shipsareneat
Post by shipsareneat »
BACK UP FOR SALE MAY '24
1988 BMW 535is (manual)
203xxx miles; located in San Diego
VIN: WBADC740XJ1718904
$5500
Photos: https://photos.app.goo.gl/M2rxVTaABBE7bdJZ7
(let me know if additional photos are requested. I will also add a video of cold start and drive)
TL;DR: a ready-to-enjoy classic that has the right stuff where it counts and is ready to offer many more miles and years to the right owner.
Bentley manual included with sale. Comments and questions welcome!
General
  • Authentic "is" including decklid spoiler, front air dam, LSD, 16" basketweaves, sport steering wheel, and sport seats
    Starts, runs, drives reliably and solidly
  • No fluid leaks or battery draining gremlins --> can leave it parked for a couple of weeks and it will start right up and not make a mess of the driveway
Drivetrain
  • Engine: good, consistent compression test numbers. Does not leak or burn oil between changes. Valves adjusted and spark plugs inspected at recommended intervals. Oil pan protected by aluminum Red46 skid plate!
  • Transmission: Smooth shifting and (believed to be) original clutch are a testament to how gently this car has been driven over the years. Fluid change at 177k
  • LSD: rebuilt by PO at 171k, fluid change at 177k
Interior
  • Handsome cardinal red door cards on black interior
  • Leather on sport seats redone by PO. However, half of passenger seat functions don't work (motors spin but cables need to be replaced). It would be a good idea to rebuild the cabling on both.
  • Working power sunroof and windows. (rears a bit slow in the cold)
  • Mostly-complete large tool kit (missing channel locks and pliers)
  • Tastefully modernized radio allows bluetooth connectivity (see pics). Rear speakers are stock and the front footwell ones are aftermarket
The bad
  • Worn shifter bushings cause side-to-side play in knob (does not inhibit shifting precision)
  • Non-functional radio antenna
  • Gas tank filler neck pinholes: can top off if you're on a road trip, but not if you're going to park it. Will not pass smog in states that pressure test the fuel tank
  • Slight driveshaft vibration under load at precisely 13 mph, related to CSB. Behavior hasn't changed over the past 25k miles so I haven't messed with it
  • Weak A/C (system converted to R134a by PO but I don't think compressor or condenser were changed to reflect this)
  • Deactivated cruise control (PO)
  • Deactivated ABS (computer and actuator are functional, but one of the Hub sensors/rotors needs cleaning or replacement to correct this. I have pulled the relays in the meantime)
  • Was lachssilber, clear coat was failing. Repainted with single stage in 2016. I still have the paint in case the buyer would like to make touchups
  • Front passenger lock doesn't work fully - rest of system is good
The ugly
  • Typical cracked dashboard
  • Left rear quarter panel met a signpost in a sleet storm (see ding in pictures)
  • Rust-perforated footwells driver and passenger side
  • Some small surface rust spots on hood and sunroof
  • Small rust hole in left rear corner of trunk
Recommended work to continue driving
  • Front lower control arms & steering alignment
  • Front tires replacement
  • Fuel tank filler neck patching or replacement (required to pass smog if your state pressure-tests the tank). Catalytic converter has been replaced and the engine runs clean; should have no trouble passing tailpipe.
  • Refurbish front seat power functions and sunroof
Background
Engineer-owned and maintained since September '15; 176k to 203k current miles. Reliable (never let me down, multiple successful 500 mi trips), fun, practical car. It was a NY car its whole life until I brought it out to CA in '18, so there is some underlying rust in the usual locations. However, the drivetrain is ready to go another 100k with the right owner. I learned so much working on this car and it has required only routine maintenance the past 5 years, but now as I balance my priorities it is time to let go, although I am not in a rush to do so.
Ideally this car will go to someone who will continue to enjoy it in its current form. Due to rust it is not a likely candidate for restoration. Alternatively, the mechanicals, interior, and "is" bits could be swapped over to a car with a healthier chassis/body/paint (maybe a 528e or auto car).
JWCIV
Re: '88 535is 196k in SoCal
Post by JWCIV »
I've seen your car street parked on Talbot across from the yacht club, haha. Wanted to park my '88 IS next to it to get a photo but it was sandwiched between two other cars. Nice car, seems like a reasonable price and hopefully goes to a good owner. Also, I've never seen that Midway shopping center parking lot so empty. Usually gotta park in China to go to Sprouts
shipsareneat
Yep that would be me! That would have been nice, I've seen a few other e28's around town but never met any owners. What color is yours?
Appreciate the comment!
JWCIV
Post by JWCIV »
Mine is Royalblau, kind of an M5 clone with shadowline and M5 wheels. It lives in Ocean Beach but sometimes I’m driving around the other side of the hill
SeattleGuy
Post by SeattleGuy »
That's a nice car at a reasonable price, especially if the buy knows DIY bodywork. Can you tell me more about who did the front seats? They look great. I have cardinal seats and it's not a top priority but something I am interested in doing down the road, thanks and GLWS.
shipsareneat
SeattleGuy wrote: Nov 03, 2020 9:43 AM That's a nice car at a reasonable price, especially if the buy knows DIY bodywork. Can you tell me more about who did the front seats? They look great. I have cardinal seats and it's not a top priority but something I am interested in doing down the road, thanks and GLWS.
Glad you think so! :D Regarding the front seats: I have many papers for garage work on the car, but don't know if I have anything for the seats. Will have to check. In any case, it would have been a shop in Long Island.
I don't know about the feasibility of pulling the ding out, but I'm sure some combination of massaging and filling could make it look decent.
However, you have reminded me of a semi-relevant detail: still have the paint from the respray in Fall 2016. So that could make the repair effort easier...
slowdawg84
Post by slowdawg84 »
Just shot you a PM, let me know if you don’t see it. Thanks!
Lee74
Post by Lee74 »
I would like to have your car, but I don’t think I can get the time off to go look at it quick enough, before someone else will probably get to it before me. I am in WA and I think it would be a bit before I could make a trip to see and get it. Nice car, and hope it’s available in a few months or to find one like it then or closer to me
shipsareneat
Lee74 wrote: Nov 10, 2020 11:20 AM I would like to have your car, but I don’t think I can get the time off to go look at it quick enough, before someone else will probably get to it before me. I am in WA and I think it would be a bit before I could make a trip to see and get it. Nice car, and hope it’s available in a few months or to find one like it then or closer to me
I will update this posting when it sells. It is still available unless noted otherwise!
shipsareneat wrote: Oct 30, 2020 1:59 AM 1988 BMW 535is (manual)
1967xx miles; located in San Diego
$3950
Thank you for taking the time to check all the right check marks in posting an ad here. Well done and appreciated.
"ding" in left rear quarter is a bit more than a ding, but besides that and the rusr, this is a nice car that seems priced appropriately. GLWS!
akaziha
Post by akaziha »
Hey beautiful car is it still available?
twuan
Post by twuan »
Still available? Im in Los Angeles, very interested.
Craigp
Post by Craigp »
Hey
Is this car still available? you can text me 504-390-0097
thanks
Craigp
Post by Craigp »
i can vemon or pay pal you cash. just have to fly out and drive it back
DFWTX85
Post by DFWTX85 »
Guys... this car has to be long sold by now. If you can find an "is" for under 4k, you better jump on it these days.
Deliveryguy55
Post by Deliveryguy55 »
Is this car available... Thanks Ray
shipsareneat
The car is available again after I got cold feet on selling in 2020. Listing has been updated!
shipsareneat
Re: '88 535is 203k in SoCal
A little surprised/disappointed by the lack of interest! Was hoping it would go to someone in this group but I'm going to reluctantly defer to Craigslist/OfferUp/FB
Sharkski
Post by Sharkski »
It's a good looking e28. Hope it stays in SD
mem
Post by mem »
hello @shipsareneat, did you sell car?
i am interested in it.
