water in back seats
water in back seats
I'm getting water on the floor behind the front seats when it rains. On both sides. Any ideas where the water could be coming in from? Seems like a recent occurrence and the fact it ends up on both sides has me confused
Re: water in back seats
Could be any or all of the following:
Sunroof drains that exit via the C-pillar
rear light seals,
boot seal
C-pillar grommets
Best regards,
Mick
rear light seals,
boot seal
C-pillar grommets
Best regards,
Mick
Thanks Mick,
Gives me somewhere to start
It might just be sunroof alignment. If it's adjusted too low in back, it will let enough water in to puddle up in the rear footwells. I'm not quite sure how it gets there, but it does. The seal isn't really a full seal, water gets thru, but the drainage system can't deal with much water. Some, but not much. Spec is the sunroof panel should be 1MM higher in back than the roof.
pulled off the covers (c pillars?) on the outside of the car and they were packed with leaves, so cleaned them up. almost stopped it, but the grommets holding them on the car need to be replaced. Anyone have a part number for those grommets. I can't find them on realoem.
This thread contains another forum members recent experiences with fitting C-pillar grommet's x 2 (item 4) and inserts x 8 (item 5).
viewtopic.php?f=3&t=157807
Some frank and helpful follow up feedback from the OP.
Best regards,
Mick
Best regards,
Mick
