Hello
can anyone share a photo of the rear hanger on the stock exhaust? Also
per real oem there appear to be 2 different sized gaskets that are between the center and rear sections - 1 is 50 mm and 1 is 47 mm. Is that correct?
thanks,
SW
stock exhaust question - rear hanger, gaskets
Re: stock exhaust question - rear hanger, gaskets
https://photos.app.goo.gl/16V2xxJRwBoGZA7U9
https://photos.app.goo.gl/FBgyse7AMkJSYW1W6
The gasket sizes are correct. The driver side gasket is held by the flares at the end of both sections, the cat pipe flare and the muffler pipe flare. The Passenger side gasket goes over the cat's passenger side pipe and is held by the muffler's flare and the cat's flange.
