Vacuum Hose Hookup
Vacuum Hose Hookup
Does anyone know where the vacuum hose from the furl pressure regulator on the S28B35 fuel pressure regulator hooks on the back of the engine nearest the firewall. I see the hose goes to the intake to the front of center, then from the back of center rearward, but the other end isn’t hooked anywhere. Thanks.
Re: Vacuum Hose Hookup
There is a Idle speed adjustment screw that is between the intake runner for Cyl#3 and #4. You can see it from directly above the engine past the fuel injector rail. Off the front of that housing there is a fitting aimed straight forward. The hose goes directly from there to the fuel pressure regulator.
Go here and look at the diagram, it is in the throttle housing for cylinders 3/4 (#2 in the diagram) it does not show the vacuum port but it is just below the screw (#33) in the picture aimed straight forward.
https://www.realoem.com/bmw/enUS/showpa ... Id=13_1089
Hi and thank you. I think that is the piece I see. One vacuum hose goes from the pressure regulator to the part in the diagram. On the opposite side of that is another inlet facing directly rearward. There is a hose hooked there and it goes back along the intake manifolds and is hanging between the firewall and the engine. I can’t imagine a vacuum hose not connected at both ends. Maybe I’m wrong?
That goes to the interior temperature sensor under the dash if I’m not mistaken.
