M5 seat backs
Etip
M5 seat backs
Post by Etip »
Hi,
My m5 has the M stripe on the back seat seat backs, but on the fronts there is no stripe logo.
The leather matches the rest of the interior and is older/worn consistent with it being 35 years old.
Is it possible that my seats came like this from the factory?
What might explain the lack of M stripes on them (other than they were recovered at some point)?
Thanks for any help/info.
RMP
Re: M5 seat backs
Post by RMP »
https://bmwmregistry.com/model_faq.php?id=7
See page 3 of this under ...interior of an E28 M5..
Thanks, Roger
Etip
Re: M5 seat backs
Post by Etip »
RMP wrote: Sep 06, 2022 10:29 AM https://bmwmregistry.com/model_faq.php?id=7
Thanks, Roger
Thanks Roger.
That's what I thought. That it should have the M stripe badge on the front seats.
So does this imply that, at some point someone swapped out the M5 sport seats for non-M5 sport seats?
Seems strange.
Then again, stranger things have happened.
///M
Re: M5 seat backs
Post by ///M »
I am not sure what the confusion is. If the M emblem breaks which they can do with age and use then they are easily removed from the seat. This is what could have happened. To replace the existing emblem with a new one then you remove the seat back and bend the pins straight and then remove the emblem.
The holes are small and can be very hard to see. Remove the seat back and have a have a look for fitting marks.
Blue Shadow
Re: M5 seat backs
Post by Blue Shadow »
Replace em and there won't be an issue with them not being there but there will be an issue that they are new and make the rest of the interior look like it needs a bit of detailing.
This vendor has the picture, others might be cheaper:
https://www.turnermotorsport.com/p-1216 ... -bmw-part/
Etip
Re: M5 seat backs
Post by Etip »
Thanks ///M there are no visible holes, but I'll pull the seatback and take a look.
