Alternative injectors
alabbasi
Post by alabbasi »
The injectors on my M5 are completely seized. I have a cleaning rig and the ultra sonic cleaner only got 2 to free up. I"m looking for alternatives and ran across this page
https://www.injectorplanet.com/products ... 4460611001
10026723 shows up on Rock Auto and not expensive. Looks different though and does not show to have a pintle cap. Has anyone used it or can anyone recommend an alternative?
TroyArboc
Re: Alternative injectors
Post by TroyArboc »
You may have better luck posting this to the tech section.
jc72
Post by jc72 »
I've used this guys services to rebuild injectors with success before. https://www.cruzinperformance.com/ He provides before and after flow test results and I believe I actually found out about him from someone on this board.
I've also used 5.0 mustang injectors on the m30 and they worked fine: viewtopic.php?f=3&t=25661
gadget73
Post by gadget73 »
just watch the flow rate. Link in the first post indicates a 24 lb/hr injector, the Mustang ones are 19#. Can usually tell by the color, orange is 19, blue-green is 24. If you do need 24, a Lincoln Mark VIII and a number of other things can provide them. No idea on the spray patter vs original.
