e28 M5 Caliper rebuild tips & suggestions
M3 Cereal
Post by M3 Cereal »
I have a 1986 BMW 528e that had both the front and rear brakes replaced
The front brakes are from a 1988 M5 and they have proved to be a headache.
I had service done roughly 2 years ago, they made a new rear driver brake line and then found that the front caliper needed to be replaced, they wanted to replace it with a new one till they realized it's unavailable / would come from a private seller and probably need a rebuild regardless. The shop went ahead and rebuilt the caliper successfully. Recently my passenger front caliper has been sticking on so I would like to have it rebuilt, Ordered the parts and have them in hand, but out of the 5 shops I visited today in SW Florida, no one will touch it, they say I have to pay whatever it cost for a new one. I am interested in others experiences with rebuild kits, and where they had their calipers rebuilt?
If no one will take the car I guess ill be doing this job myself, From researching this job doesn't look all that involved, I just like the idea of a professional working on my brakes
Any suggestions or tips are welcomed
Currently, these are the parts I have, will I need anything else?
Thanks
Repair Kit - Brake Caliper (4 Piston)
Part #: 34-11-1-158-692-INT
$40.25
Guide Bushing Repair Kit - Brake Caliper (Front/Rear, Left or Right)(5-Series E28 (1982-1988))
Part #: 34-21-6-869-617-M4
$11.75
x2 Caliper Guide Pin (Front/Rear, Left or Right)(5-Series E28 (1982-1988))
Part #: 34-11-1-157-041-M4
$13.00
Front Caliper Carrier Mounting Bolt (4 per car, sold individually)(5-Series E28 (1982-1988))
Part #: 34-11-1-151-604-BOE
$2.75
Brake Pad Sensor (Overall Length 260 mm)
Part #: 34-35-1-179-819-BOE
$12.92
Below is the service order from the shop in Maryland, Yes they charge an arm and a leg, but in the end they completed the job.
_______________________________________________________
TECHNICIAN REMADE DRIVERS SIDE REAR HARD
LINE FROM CALIPER TO SOFT LINE, BLED
SYSTEM AND FOUND LEAK AT HARDLINE ON BODY
ON DRIVERS SIDE, REPLACED SECTION OF
BRAKE LINE AND REBLED BRAKES, BRAKES ARE
NOW WORKING BUT FOUND DRIVERS SIDE FRONT
CALIPER CENTER PISTON SEIZED, NEED TO
REPLACE DRIVERS FRONT CALIPER
REMOVE DRIVERS SIDE FRONT CALIPER AND ATTEMPT TO REBUILD CALIPER $475.00
Part Qty Total
BRAKE FLUID DOT 4 1000ML
EFM1103 N44 - 2 $25.98
Job Total
$500.98
Labor Total
ATTEMPT TO REBUILD CALIPER $332.50-
Part Qty Total
BRAKE CALIPER PISTON
146.40005 I7 - 4 $99.96
CALIPER REPAIR KIT-F
34 11 1 158 692 I7 - 1 $24.99
Job Total
$457.45
Philo
Re: e28 M5 Caliper rebuild tips & suggestions
Post by Philo »
Well, I've been promoting Caliper HQ in Signal Hill CA but he'll by the time you ship them west, get them rebuilt and sent back it might be a scratch price wise.
Give them a call, I'm just guessing on the cost. Who knows, might be less.
https://caliperhq.com/ talk to Graem or Dan.
