Head gasket? Or something worse?
Posted: Feb 05, 2024 9:28 PM
Hey folks, I’m hoping the collective horsepower of this group can help me save my S38. Or tell me I’m SOL.
I was dropping the kid to school the other morning (Nor Cal so >50 degrees), engine braking from like 2-3k to slow down for an exit when the engine starts making a bad rattling noise. Like a clattering. Coming from inside the engine only at load at like 1.5-2k rpm.
Dropped the kid off, very gingerly drove home (<5min), car was not happy, parked her and had her towed to the shop.
Car recently had >$10k of work done to her (non engine related) and was running beautifully. I’ve owned her for 8 years, annual oil changes, premium gas etc. She’s been treated well, and I do daily drive it switching between my e39 and e28 for months at a time. Refinished wheels recently, with new tires and rotors and stainless steel brake lines, new clutch master and slave etc. She has not been neglected. 155k miles. Less than 500 miles since last oil change.
Shop dove into it, found a disconnected throttle position sensor and valves “way out of spec” (she just had a valve job not even 12 mons ago smh). Car is idling “perfectly” and making power, but still makes the rattling noise above 2k. They obv dont want to drive it.
They did a compression and leak down. All cylinders except 4 and 5 were 160+ on compression. 4/5 were sub 50. Yikes.
However, 4/5 are reading perfect on leakdown at TDC. Which is pretty strange right? They are boroscoping everything tomorrow. Shop thinks its the wrist pins making the noise (which my ignorance suggests wouldn’t impact compression?).
Naturally I called another shop I have become friendly with that works on 80s M Bimmers, they are suggesting given the proximity of the cylinders, this might be a head gasket failure at higher compression where the cylinders are fighting / cross firing causing the rattling under load. There was oil leakage from the head gasket.
Obviously an engine rebuild is a bit of an undertaking on these things, and before I go down that rabbit hole, I’m wondering if
(a) anyone has had this or something similar occur,
(b) any other obvious investigative ideas before they tear down to look at the head, or
(c) know which LS fits best under the hood (I kid, I kid).
Thanks so very much. Happy to answer any questions (as much as I can); apologies if I missed adding any pertinent info, my brain is a little frazzled at the potential cost of fixing.
Kamran
Kamran
