Using A Scavenge Pump w\ A Turbo Set-Up
slownrusty
Post by slownrusty »
Hey Guys - on my turbo, I am running an old(er) Dinan cast manifold and the turbo sits very low.
The fitting for the gravity drain on the turbo is pointing directly at the fitting on the block. I am wondering if oil could back-up into the turbo or at least make it difficult to drain. Last thing I want to do is damage the turbo seals.
One way to address this is with a scavenge pump.
Thoughts? Happy to provide a few pictures if it helps.
Thanks,
Yasin
