'86 535i: Pulsing rich idle, poor gas mileage, runs fine under load.
Posted: Aug 25, 2024 11:17 PM
I'm the second owner, purchased in 2018. The car idled and ran fine but was lacking power, and an inspection of the cam while adjusting the valves showed the cam was worn. Approximately two years ago I replaced the worn stock cam with a 276 from dbilas, along with HD rockers from IE, resurfaced the head and had new valve seals installed. During this refresh I replaced any vacuum and cooling system hoses that looked worn, and also replaced the timing chain guides and tensioner. After getting the car back together, the idle has been rich and lopey/pulsing, and shakes the car intermittently. Gas mileage is awful, the exhaust smells of sulfur and there are drops of gas exiting the tailpipe. I triple-checked the timing before sealing everything back up, and the car runs fine under load, so I don't think that it is a timing issue (but I could be wrong).
Thinking it could be a fuel delivery issue, I replaced the injectors with flow matched Bosch, installed Bosch WR9LS plugs, new Bremi plug wires, new cap & rotor, new FPR, adjusted the throttle body and TPS, and even replaced the oil filler cap. No change. I thought "this is just how the cam must be" and decided to live with it.
A recent conversation with my brother led me to think the car may be running in open loop, so I decided to try to tackle the issue from a different angle. Within the last few days I replaced the O2 sensor, tested the CTS, and checked/cleaned the battery to chassis ground, the engine to frame rail ground, the head to firewall ground, and the harness to head ground with no change in the idle. When testing the new O2 sensor with a multimeter, I stuck one lead in the white male connector by the passenger firewall and the other lead on a ground, which caused the engine idle to even out somewhat immediately (while measuring .462v). I tested this several times with the same result, before and after checking the grounds. This leads me to believe that there could be an electrical issue, but I've checked and confirmed all grounds in the engine bay are clean and secure. The only time the idle will somewhat even out is if I do the O2 sensor test above.
The cluster board has a short which causes the "inspection" light to stay on and the speedometer to jump occasionally, but it has had this issue since I purchased the car from the original owner and did not cause any running issues pre-cam replacement. There are no other electrical issues I know of. The car drives fine under load, and reminds me why I don't like to drive it when I pull up to a stoplight and it idles rough with the shakes.
I've also installed a Mark D chip in hopes it would help with the idle, without success. Video of startup and idle is below (I rev it for a few seconds from the throttle body). Any help or insight would be greatly appreciated.
https://www.youtube.com/watch?v=k2eMe_RqRdE
