Posted: May 21, 2005 1:56 PM
by Robbie
do U.S. M5's have rear fogs built in the shadowline tail lamps?
TIA
Robbie
Posted: May 21, 2005 7:55 PM
by Rich in Tupelo
To my knowledge, no US cars (including the M5's) had the rear fogs built in. But, I am sure that they can be wired in after the fact.
Rich
Posted: May 21, 2005 8:46 PM
by BDK
jsut add the bulbs and find a euro fog light switch and ding you have rear fogs I believe....
Posted: May 22, 2005 12:13 AM
by Robbie
Thank you, thank you
Posted: May 22, 2005 12:33 PM
by Devinder
Do the rear fogs go in the empty socket on the tail-light housing? If so, the US M5 is no different than any other E28. The harness has no wire going to that place on the connector. Last week I used that place to add a brake light and I had to make a spade connector to fit in the connctor housing and jumper a wire also.
Devinder
Posted: May 24, 2005 12:18 PM
by lkfoster
[QUOTE="BNC"]jsut add the bulbs and find a euro fog light switch and ding you have rear fogs I believe....[/QUOTE]
That's what I did. There are some blank pieces that you break out to install the bulbs. You can choose to either do one side or both, depending on which country's rules you want to follow. I'm running one to avoid having them look like brake lights.
I also installed the euro dash panel symbol strip. I don't have the p/n anymore though.
Posted: May 25, 2005 11:07 AM
by Azure
Actually.. I plan to do just that, wire the "fog lamp" empty slot as an extra brake light.
