MLS m30 or m20 Head Gasket Sale!
OK guys. I received my tentative pricing. I'll be able to offer the gaskets at $210 plus shipping. M20 gaskets are available now. M30s in a few months. Gaskets are available in 4 thicknesses.
.070 stock
.080 for a shaved head
.120 for ~8/10s point compression drop
.140 for ~12/10s point compression drop
.80, .120, and .140 gaskets are an additional $10.
I have a .120 gasket coming next week for the Buzz Bomb.
Please post here if you want one. It's still a few months away but I need to place my order now. Hey Ken, S38 gaskets will be aavailabel as well. Similar pricing I would assume.
Thanks,
Todd
[Edit by TCD on [TIME]1122577970[/TIME]]
Not that I'm particularly interested in replacing my headgasket again, %) but are there any peculiarities associated with these headgaskets? Just install and use like a normal one? Seal fine when cold and all that (unlike copper)? I'm curious.
[QUOTE="Jeremy"]Not that I'm particularly interested in replacing my headgasket again, %) but are there any peculiarities associated with these headgaskets? Just install and use like a normal one? Seal fine when cold and all that (unlike copper)? I'm curious.
Jeremy[/QUOTE]
Installs like a normal gasket. Acts like a normal gasket with much more holding power!
Todd
Bill in MN
Post by Bill in MN »
Sign me up. You know what I need for the new motor.
Velocewest
Post by Velocewest »
Is there any difference in gaskets for the M106 (vs. M30)? Seems like this would be as good or better than whatever BMW sandwiched in there.
[Edit by Velocewest on [TIME]1122578894[/TIME]]
[QUOTE="Velocewest"]Is there any difference in gaskets for the M106 (vs. M30)? Seems like this would be as good or better than whatever BMW sandwiched in there.
[Edit by Velocewest on [TIME]1122578894[/TIME]][/QUOTE]
Nope no difference.
gol10dr1
Post by gol10dr1 »
question, my car will be tuned for a 9.0:1 compression. i am assuming that if i change the compression by head gasket (say 8.5:1) i would have to have the car retuned right? so if this is true then put me down for a stock comrpession gasket. and the sooner the better. hopefully this one will hold for a while.
[QUOTE="gol10dr1"]question, my car will be tuned for a 9.0:1 compression. i am assuming that if i change the compression by head gasket (say 8.5:1) i would have to have the car retuned right? so if this is true then put me down for a stock comrpession gasket. and the sooner the better. hopefully this one will hold for a while.[/QUOTE]
No. You won't have to retune the car. A .120 should be great for your car. Drop the compression to ~8.2
Todd
///ARINUTS...
Post by ///ARINUTS... »
What if I have my block o-ringed?Can I use an MLS gasket?
