Squirrelly rear end
Tjn182
Post by Tjn182 »
So what's the cause of a squirrelly rear end?
Someone might jump in and tell me it's my subframe bushings
some might say dogbones or rear swaybars
well you're all WRONG! :p
Last night I went out with my roommate and drove around Myrtle Beach, SC (I just got back). Well I turned up the boost juuuuust a little (I've been driving with the gauge reading around 7-8psi, bumped it to read 10-11psi) and took her out for a spin.
In second gear I was just steadily driving at about 2000 RPM when I floored it - at about 3500-4000rpms at about 35+mph my tires break loose and my back end is squirrelling (?) all over the place! Man... this car can FLY!!!
And it was a dry night, about 80 degrees and it was on a flat surface so there.
And I don't want to hear from Mr. Todd about how he busts loose in 4th gear! ;) This is a first for this vehicle and I'm darn proud!
Boru
Post by Boru »
How 'bout breaking loose the 245s in 3rd gear.... at 60mph?
Sooo, when does the creep up a little higher? Addicting, isn't it :cool:
Jesse
Post by Jesse »
What gears are you running??
Tjn182
Post by Tjn182 »
[QUOTE="Sweeney"]How 'bout breaking loose the 245s in 3rd gear.... at 60mph?
Sooo, when does the creep up a little higher? Addicting, isn't it :cool: [/QUOTE]
Hush you! :p
Jesse - I'm running the standard 3.25 limited slip - I'm wanting to get a 3.73 limited soon
rundatrack
Post by rundatrack »
Are you getting a chirp...or ya talking like oh shyte let me let off before my car slides sideways...
Either one is amazing by the way....*two thumbs up*
Aaron from Aus
Post by Aaron from Aus »
What Wheel size, Width, and tyre pressure do you have out of interest?
Boru
Post by Boru »
That was with 3.46 lsd, 20psi boost, 245-50-16 BFG G-Force KDW tires... just rolling into the throttle in third gear from around 40mph and lettin gthe torque overcome traction... tires started "scrubbing" while climbing towards 60mph... I let them scrub away for a second or two.
[QUOTE="Sweeney"]That was with 3.46 lsd, 20psi boost, 245-50-16 BFG G-Force KDW tires... just rolling into the throttle in third gear from around 40mph and lettin gthe torque overcome traction... tires started "scrubbing" while climbing towards 60mph... I let them scrub away for a second or two.[/QUOTE]
I miss driving that car during the winter. Just killing the tires in 2nd gear. Spinning like crazy at 60mph.
Todd
