i have a boost/vacuum gauge...
i need the best place to tap a vacuum line
for my gauge...
i don't have a turbo on it yet, but i do want to
check the vacuum at idle and such....
where can i tap a vac line that wont interfere later when i
put the tcd s1 kit in?
are certain places more accurate than others?
e34 m30 so its the b5 thanks guys!
where do i mount my boost gauge?
The b35 motor has extra, UNUSED vacuum ports on it??? Holy crap!!
The easiest place to get a vacuum signal is the line to the FPR. Cut it, stick a T on it, and plumb your gauge into the T. If you don't want to do that, you could always plumb it to the port that the e28 uses for the cabin temp sensor, but that's the one that's usually used for the wastegate on the turbo. My boost gauge is plumbed into the FPR signal line, so if you're looking for an easy transition from N/A to turbo in terms of your boost gauge, that's what I'd recomend.
Hardest part for me was getting the damn line to go through the firewall grommets!!
