Is it me...Vid
rundatrack
Post by rundatrack »
Or this car is barely spooliing this turbo.....guess someones math is off...or just went big for talks sake...
Huge Turbo....No Spool
booker
Post by booker »
It's spooling a little, but without a load, it's not going to produce much boost, I'd say.
But then, I don't know much about this stuff.
rundatrack
Oh I see what your saying...
bmwfan2304
Post by bmwfan2304 »
also... don't rotary engines have an extremetly high redline? in fact i thought they didn't have one but were limited by the ability to pump gas and such... Anyway, even though he's holding the gas down for a couple seconds it may still be really low in it's rev range... don't know if i'm right but it makes sense to me... :D
Yellow2
Post by Yellow2 »
they do have their limitations, but they are much higher in the 12K+ range over our wonderful valved engines. My friend charles had a TurboII 2rotor that he took me for a ride in and he always rode that babyy in the 10K+ range making the engine screwm, but also the rear end swing out of control sometimes.
he ended up totaling the car when he flipped it i think some 8x in 2nd gear after flying into a ditch. silly kids need to learn control before they get into some of these cars. he said the car was at 14.5K rpm when he threw it out of 2nd and lost control.
3 rotors are beautiful engines.
Matt
Post by Matt »
The factory redline on the RX production cars is around 9k.
Yellow2
Post by Yellow2 »
a redline never stopped anyone from going past it. :p
Tjn182
Post by Tjn182 »
Looks like he was revving that sucker in neutral - which means that there is almost no "work" being done to power the turbo. But being able to spool up a turbo in neutral usually means decent spool times (i believe) - I try WOT in neutral sometimes and I see like .1psi of boost...
kendogg1
Post by kendogg1 »
if that thing is a rotary, why does it look like an inline 6? Count the tubes comming out of the intake manifold.
bmwfan2304
well i know nothing about rotary engines... can't say i've even seen one.. but if someone with an RX-7 is gonna go turbo... why would they discard a rotary engine? those have mean top-end power when turbo-equipped.
[QUOTE="kendogg"]if that thing is a rotary, why does it look like an inline 6? Count the tubes comming out of the intake manifold.[/QUOTE]
Rotarys have 2 intake ports per rotor and each port gets its own intake runner. Since its a 3 rotor, it has six intake runners. Rotarys also spool much larger turbos than a piston engine of similar size for a few reasons. The main difference is the amount of combustion events per 1 revolution of the eccentric shaft. There are 3 combustion pulses from just ONE rotor in one e-shaft revolution. Now consider two, three or even four rotors. This higher density of exhaust gas per rev helps to spool the turbo much better. There is physically more exhaust exiting in the same amount of time. This is also the reason for the high power output from such small displacement.
The other factor is spoolup is how the exhooassed port gets "opened". Instead of a valve in a piston engine gradually opening over a few degrees of crankshaft rotation, the rotary uncovers its exhaust port almost intantly and the exhooassed gas rapidly spills out the port with a much higher velocity(kinetic energy) and also helps spool.
My brother is a huge rotary nut and has an '87 TurboII with a fresh engine that we built which is why I know more than I should about these strange beasts. Its a fun, fast car but it definitely has its quirks.
