M106 question
Velocewest
Post by Velocewest »
Does anyone have handy the bore, stroke and rod length for the M106 block?
Thanks
[Edit by Velocewest on [TIME]1132939096[/TIME]]
Velocewest
Maybe an easier question -- is stroke and rod length the same as another M30, i.e. same rods and crank as 3.3 or 3.5? I do still want to know the bore if anyone has the spec.
EDIT: Note to self, don't ask tech questions before caffiene has kicked in...
[Edit by Velocewest on [TIME]1132940798[/TIME]]
Velocewest
OK, full circle.
Second note to self -- remember that once caffiene kicks in, you will remember how to Google.
Engine Type: 36 6E
Effective engine displacement (cm) 3430
Stroke (mm/in) 86 / 3.386
Bore diameter (mm/in) 92 / 3.622
Performance accord. to DIN KW/HP 185/252 at RPM (1/min) 4200
Maximum torque Nm (kpm) 380/38 at RPM (1/min) 2200
Maximum RPM (1/min) 6200
Compression ratio 8.0 : 1
Combustion chamber volume (cm/in) 59.5 1 / 3.63 0.06
Compression pressure (bar/psi) 8-9 / 116-130.5
Cam shaft 264/112
Running clearance of piston (mm/in) 0.04 / 0.0016
Valve diameter (mm) Intake valve 46
Exhaust valve 38
Valve clearance, cold (max. 35C water temp) (mm) 0.30 (0.012 @95F)
Oil pressure (bar/psi) 4-5 / 58-72.5 at max RPM
Oil capacity (liters/quarts) 5 l + 0.75 w. filter / 5.3 + 0.8 w. filter
Engine cooling fan 9-blade
Thermostat 80C / 176F
Ignition Digital-Motor-Electronic
Ignition sequence 1-5-3-6-2-4
Distributor High voltage distributor
Ignition timing (control value) 12-14 before TDC (warm and at idle)
Sparkplug Heat value 145
Spark gap (mm/in) 0.7 +0.1/-0 / 0.028 +0.004/-0
Ignition coil Bosch No. 0 221 118 335
CO-Value 1.5 Vol. %
RPM at idle (1/min) 800 50
Fuel processing Digital-Motor-Electronic
Fuel pressure (bar/psi) 2.5 0.05 / 36.3 0.73
Sounds exactly like an m30b34 green motor, except with a the dirty motor cam. Interesting combo.
