Used Turbo Kit
dpstk
Post by dpstk »
I was thinking about purchasing a small turbo from a friend. I don't know the stats on it as of yet. It will however have to be resealed and I was wondering two things. 1: Where canI send it to be redone and 2: If I am buying the turbo what else will I need to buy to make it work? (I am new to this). I can post the info on the turbo but are they easy to make work on the E28 if it is a modern turbo... no computer mods etc?
[QUOTE="dpstk"]I was thinking about purchasing a small turbo from a friend. I don't know the stats on it as of yet. It will however have to be resealed and I was wondering two things. 1: Where canI send it to be redone and 2: If I am buying the turbo what else will I need to buy to make it work? (I am new to this). I can post the info on the turbo but are they easy to make work on the E28 if it is a modern turbo... no computer mods etc?[/QUOTE]
Don't buy anything until you have done your research. Do NOT start your build by buying a small turbo. You need to decide what manifold you will you use prior to buying a turbo.
Todd
dpstk
Post by dpstk »
Todd
Any you recommend?
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
You can start you general turbocharging research with the "bible" : Image
and then go here to start your BMW engine turbocharging research: http://www.turbochargingdynamics.com/
Mike in Louisville
Post by Mike in Louisville »
^^^^ Read that book! Especially if you're going to do an ' la carte' turbo system and not a kit that's already been researched. But you should still read it either way so you won't be ignorant about what you have.
gol10dr1
Post by gol10dr1 »
why a tcd manifld should do the trick!
Tjn182
Post by Tjn182 »
Yeah.. you cant just buy a used turbo and make a kit if you have no idea what you're doing. Read that book and you will be bestowed with all of our knowledge (except experience) and power! Otherwise... you're probably just ask us a billion zillion basic questions that could have been easily answered in that book.
dpstk
Post by dpstk »
I understand. I am not sure if I even want to put a turbo on it or not. But thanks for the info.
Tjn182
Post by Tjn182 »
If you're in Valdosta, hit up Yellow in Atl -- i'm sure he wouldn't mind giving you a crash course in turbochargers -- maybe you can decide on what you want to do from there?
Yellow2
Post by Yellow2 »
my roommate is from valdosta, its a 2hr or so trip i think. lemme know if you wanna come to ATL.
