Track Pipe Dyno Results
Posted: Apr 08, 2006 9:41 PM
Dyno fun at New England Dyno on a cold and rainy day....
#2/Blue - Baseline (5th Gear)
#4/Red - Fahey Track Pipe (5th Gear)
#5/Green - Fahey Track Pipe (4th Gear)
Car details:
- E28 M5 125k miles (~15k on refreshed engine)
- JC Chip
- Fahey crank hub
- Evo valve springs
- Al Flywheel
- Stebro Cat back
We dynoed, pulled the cat, told bad driver stories while John went to get new exhaust hardware, put on the track pipe, and then dynoed again so I think we got a pretty good A:B comparison. I'm not really sure how dyno's work in terms of gearing but John was convinced 5th was an overdrive gear (I thought it was 1:1 on our cars) so we did our last run in 4th and as you can see it made another ~10hp or so so I'm not sure which gear is a better/more accurate representation of power.
The good:
- The track pipe not only added 7 max hp but also added 8-15hp everywhere over 5800rpm.
The bad:
- Big torque dip max of -22ft/bls / -15hp @ 3300rpm. This was noticeable even as I was running the M on the dyno as the car was definitely slower to run through this rpm range. I can also notice the loss on the street however @ 3700rpm the track pipe takes over making the car feel faster as the torque comes in steeper from 3300-3700. I want my torque back! Is that hole something that can be tuned for?
- The car is also even louder now. It was slightly too loud with the cat in there thought it was just right at the track but now it is definitely too loud. I actually thought it was quieter with the pipe at first but once my ears adjusted back to normal after running the M all the way to 162mph inside the shop, the car is definitely boomier. Deeper, with a less tight more resonating bass to it.
The notable:
- The Fahey track pipe has an H pipe in it but the O2 sensor isn't on the H, rather it is after the H on one pipe. I don't know if that matters but I thought it was strange.
- John thinks there's more power to be made if we could adjust the A/F ratio and keep it closer to 13:1 everywhere. Any thoughts?
- My tach shows ~7600rpm before the limiter cuts in but as seen on the dyno the chip actually redlines @ ~7250rpm.
I'll keep the track pipe in for a while since there are a bunch of hpde's coming up and I don't think the car is so loud that I'll get flagged for exceeding db limits (off the street that is). I would like to make it a little quieter though so I can run the track pipe without even more evil stares from the neighbors than I already get. I loved the sound before but I was definitely on the line of my personal db limit. I'm thinking maybe just swapping the center resonator with a supersprint/stock item might do the trick.
Car details:
- JC Chip
- Fahey crank hub
- Evo valve springs
- Al Flywheel
- Stebro Cat back
The good:
The bad:
The notable:
