HUGE HP numbers from FI S38.................................
Posted: Apr 10, 2006 8:45 AM
Lets try this again, try to stay on topic this time guys.
707.2 rwhp
Yes, its Ken Hawkins car. He has a 1988 M5 with the S38B34 engine. Care weighs 3360 lbs. Here is a quote - "The car is tractable enough when not in boost. Things begin to change character when I reach 3-4#. One is conscious of the fact that this is very much a race motor now and the whole package is highly intolerant of driver inattention or judgment shortcomings. Get above 3500rpm and 5# boost and You Just Got The Real Deal, Mister. Found a piece of straight open road w/ good visibility and laid into it @ 7.25 psi (low-range boost), holding shift points @ 5000. Ridiculous. It breaks traction all the way up to and including 5th gear.I am very glad I put in the Quaife differential. Given the sizing of the T66, one is real close to surge values when below 3500 and the wastegate is set to 15#. So going into full boost isn't done from standing starts. Pushing the "Loud" button is a religious experience. "
He has taken his FI engine build and system to a much higher level. I can not touch the amount of money and engineering he has in his car.
As far as why he left the board, I am not going to get into it or want too. He just felt like a lot of people were questioning his technical abilities and obviously he did not like that.
PS - I sent the full sized images to Jeremy to host. Once he posts them, you can then see all of the details on the graphs.
707.2 rwhp
