36-1 toothed wheel postion?
Does the missing tooth point straight up at TDC? Or is there a certian degree of advance or retard it is supposed to be at?
Explain the "60 degrees from the missing tooth to the VR sensor" please... related to???
The missing tooth needs to trigger the VR sensor more degrees before TDC than the maximum spark advance programmed into the ecu. 60 degrees is common but I'm not sure this is what Bosch used... pretty simple to measure.
The missing tooth VR sensor combo tells the ecu "You are 60 degrees BTDC, prepare to fire"....
