spark plug wires?
spark plug wires?
putting in a megasquirt system, along with msd 6al ignition, the msd box says on the outside do not use sold core wires. I have had several people tell me they have not had any problems with this set up. Why are you not supposed to use solid core wires? Will the performance wires banded copper make a difference. Cant use msd wires because the ends that go into the distributor dont fit bmw's
Good ignition wire tech:
http://www.magnecor.com/
I've used Magnecor for a bunch of projects including a TEC-2 install on a Ferrari 308 with great results. They also made me a set of wires for my old E28 with a custom coil wire to allow use of an aftermarket 5.0 Mustang coil.
Ditto -
I am using them with my EM Tec3.Good ignition wire tech:
