supercharging
Posted: Jun 01, 2006 4:24 PM
by rosie_83
Any of you guy's and gal's ever super charged a m30? Spoke to tcd and the kit won't fit rhd and the only turbo kit in the uk only gives 280bhp (£5000 for 60bhp seems a bit on the pricey side to me). Been talking to fritz's bitz and he's advised a rse centrifugal internal compression supercharger would be my best bet, lowering the compression with an ali plate. Any advice would be much appreciated.
Baz (uk)
Posted: Jun 01, 2006 7:42 PM
by rundatrack
www.pure-pf.com
Swedish company the owners name is andreas I believe
If you go to that site or
www.bimmerforums.com in the forced induction group and look up bmwandreas you should be able to pm him on what options you have...
Hope that helps..
and his msn Im is
aa@pure-pf.com
hope that helps...
Posted: Jun 02, 2006 6:26 PM
by Mobydick
You can use the procharger P-1SC with the TCD ecu chip.With stock internals you can boost up to 14psi.
http://www.procharger.com/models.shtml
Re: supercharging
Posted: Jun 02, 2006 8:47 PM
by M635CSi
rosie_83 wrote:Any of you guy's and gal's ever super charged a m30? Spoke to tcd and the kit won't fit rhd and the only turbo kit in the uk only gives 280bhp (£5000 for 60bhp seems a bit on the pricey side to me). Been talking to fritz's bitz and he's advised a rse centrifugal internal compression supercharger would be my best bet, lowering the compression with an ali plate. Any advice would be much appreciated.
Baz (uk)
No affiliation, but these people have done right hand drive M30 turbo systems for the E28...
Workshop address:
Bavariacars Motorsport
Unit D 39 College St
Gladesville N.S.W 2111
Sydney Australia
http://www.bavariacars.com.au/
Postal address:
P.O Box 3103 Gladesville 2111
Contact numbers:
Telephone: +61 2 9879-7557
Fax: +61 2 9879 7505
Email:
info@bavariacars.com.au
Business hours:
Mon - Fri: 8.00am to 5.00pm
Sat: By appointment only
Re: supercharging
Posted: Jun 03, 2006 5:28 PM
by gol10dr1
Workshop address:
Sydney Australia
Postal address:
Contact numbers:
Email:
Business hours:
are you the dude with the turbo 635 that was featured in performance bmw mag a while back?
Posted: Jun 05, 2006 4:48 PM
by rosie_83
Thanks for all the replies, think i'm gonna go for the procharger as i've been talking to a few companies in the uk and it's gonna be the cheapest option by far.
Would an intercooler be a good idea as well and should i go low compression with an ali plate between the head and block?
Posted: Jun 05, 2006 5:29 PM
by Mobydick
An intercooler would be better and if you lower the compression to 8.0:1 you can boost more. If you have the one with cat converter you don't have to lower your compression,because it's already 8.0:1.An option is to replace the stock pistons for JE forged pistons.
I have a supercharger set up that cost me $4500 and the internals cost me $2000.
Posted: Jun 05, 2006 5:58 PM
by rosie_83
havnt got a cat, didnt need them in the uk till 92 i think, would there be much difference between forged low comp and the ali plate? What sort of power can i expect with low comp and an intercooler?
Re: supercharging
Posted: Jun 06, 2006 1:07 PM
by M635CSi
gol10dr1 wrote:No affiliation, but these people have done right hand drive M30 turbo systems for the E28...
Workshop address:
Sydney Australia
Different dude...
Posted: Jun 11, 2006 11:01 AM
by originalMJG
im also in the uk and am considering these options. plenty of people have done RHD turbo e30's with the m20 engine. the problem is locating the turbo and routing the exhausts i beleive?
if your handy with fabrication, then you could manufacture/modify a manifold so that the turbo is on top of it roughly in line with cylinder 2, then route the exhaust immediately down then tuck it up under the standard manifold and hugging along the block down the gap next to the steering box.
for inlet it should be easy, then you could route the output of the compressed air to the front for a FMIC at the side of the car then back up again past the distributor and over the cam cover.
oil feed wud be simple enough.
am i missing something? please someone stop my thoughts with some kind of fact. maybe bonnet clearance would become an issue but probably would fit.
Posted: Jun 11, 2006 11:59 AM
by Skeen
originalMJG wrote:im also in the uk and am considering these options. plenty of people have done RHD turbo e30's with the m20 engine. the problem is locating the turbo and routing the exhausts i beleive?
It's definitely possible if you can fabricate. It just takes skills and time. The original poster seemed to be looking for something a little more bolt-on, which is why the discussion went in the direction it did.
Posted: Jun 11, 2006 12:31 PM
by M635CSi
Posted: Jun 11, 2006 12:38 PM
by originalMJG
any more pics of the engine bay there m635csi? looks good as ive seen the TCD kits using the chargecooler which is something i would rather avoid for simplicity and potential power gains. is that a 745i? it looks very "oem".
preferably any pics from the other side? ive seen a picture of an s50? turbo in an e30 which is the general layout i was considering for the turbo. it was black, with LARGE front mount intercooler and big turbo sitting high.
skeen - yeah i understand the bolt-on idea but was just tossing ideas around that i had in my head
Posted: Jun 11, 2006 2:56 PM
by M635CSi
originalMJG wrote:any more pics of the engine bay there m635csi? looks good as ive seen the TCD kits using the chargecooler which is something i would rather avoid for simplicity and potential power gains. is that a 745i? it looks very "oem".
Bavariacars Motorsport (I believe) did that turbo installation in a customer's car. They've also done at least one right hand drive E28 M535 with the same layout and front mounted intercooler. I seem to recall they used a Mitsubishi turbocharger with an internal wastegate. There are more images but they won't be available until my new server is online.
Posted: Jun 11, 2006 3:19 PM
by originalMJG
ok thanks for that, il look into it some more
Posted: Jun 11, 2006 4:20 PM
by russc
Oh my, that engine bay is packed....
More pics would be great though.
Posted: Jun 14, 2006 8:51 AM
by gaijin
Posted: Jun 15, 2006 9:44 PM
by Azure
http://www.bavariacars.com.au/article/?id=42
I own the issue that car was in - it got me really interested in turbocharging, at the time I had my E12 520i, same basic engine! The memories.... *sniffle*
