http://www.craigslist.org/eby/pts/168480396.html
Links to any suppliers would also be nice. Thanks guys!
So exactly what else would I need to make this work...
From what I can see,you need the following.
1) Lots of beer.
2) Longer 8mm exhaust studs to attach e.manifold to the head.
3) A pipe to get from the turbo to the intercooler.
4) Maybe a custom motor mount depending on model.
5) No ABS if you decide to use that intercooler
Cant think of too much more. Maybe in the morning.
1) Lots of beer.
I also have a 533i so I don't have ABS from the factory (bonus?).Yellow2 wrote:From what I can see,you need the following.
1) Lots of beer.
2) Longer 12mm exhaust studs to attach e.manifold to the head.
What about the fuel and timing requirments?
Any idea about the block?
I am running the same 008 ECU and I maintain stock boost (8psi) with the wastegate. I have stock 533i injectors. The no ABS is a plus as the IC pipes right there. Here is a pic of my IC through the front. Stock fuel pump, fuel filter change, premium gas, stock block but its changed from an '87 m30 535iS motor. I see no problems running stock boost levels. If yo uwant to run higher, get an 059 ECU and get larger injectors + rrfpr or talk to TCD about getting a made kit. A little more and you get great help. Here is how mine is setup.
http://usera.imagecave.com/tjn182/intercooler12121.JPG
12mm studs - Are you high?Yellow2 wrote:From what I can see,you need the following.
1) Lots of beer.
They're 8mm.
and to add-on to #4 - a 533i passenger's side mount works well too.
