745i dme part# s
Posted: Jul 16, 2006 2:52 PM
by davidu
Hey folks,I purchased a 745i wiring harness with dme and all for turbo convertion and was wondering in fact if it is correct as listed on ebay.It is a 013 , I am wondering because all i have read hear of is 059 and 061 part#s .Any info on 745i turbo dme's would be help full
Posted: Jul 16, 2006 3:10 PM
by Mark 88/M5 Houston
There is a list at the bottom of the page on this link.
http://www.pelicanparts.com/BMW/techart ... Repair.htm
Posted: Jul 16, 2006 3:18 PM
by davidu
Thanks,I was on pelican parts and searched part# but nothing came up.Thanks for the help and link
Posted: Jul 16, 2006 5:10 PM
by 345is
yes that is the correct DME for a 745i with an M106.
Posted: Jul 16, 2006 6:53 PM
by Damon in STL
I second that. The 013 is from the 3.4 745i.
Posted: Jul 16, 2006 11:37 PM
by Jimmie G
The 013 was better known for its nickname "piggyback" because unlike the us 735 635 535, 059 ecu the 4hp22eh ecu was seperate from the dme on the 745 they were combined on top of each other thus why we called them piggybacks.
Jimbeaux
Posted: Jul 18, 2006 11:08 PM
by davidu
well, i am using it to convert my 533 to turbo,any one know of any errors in this. I am using dme's harness afm and injector so far.I am going to use a saab turbo(garrett ar.48)and make
the manifold,but thats another battle.........
Posted: Jul 18, 2006 11:10 PM
by davidu
Are all m30 ARP head bolts the same?
Posted: Jul 19, 2006 12:45 PM
by Velocewest
If you're not installing the full 745i turbo setup, why bother with the ECU? It's arguably the worst choice, because it is set up to interface with the 4hp22 controller and it limits output based on BMW's purpose of the 745i -- big, smooooove cruiser with a lot of torque. You'd be better off using the ECU from an e28 or e34 535i if you want a factory box.
Posted: Jul 19, 2006 6:46 PM
by davidu
Well thats not good to hear, I should have asked before i bought them. How does the dme react if the trans controller isn't seen if dme is from an automatic or is it even monitoring communication with it . I know what happens on newer bmw's but i didn't think about when i got'em.
I am only trying to gain an increase of what the 745 put out stock or little more,My original reason for buying them was piggy back dme is supposedly have knock control with it and that alone would help a great deal,but e34 dme would have that..
This weekend I'm installing new headgasket and arp studs!!!!!
thanks for replies
Posted: Jul 19, 2006 7:14 PM
by Velocewest
Unless I'm mistaken about the later versions, all 745i's use a standalone knock-box that just sends a signal to the DME. And if you don't have the engine block frm the 745i you don't have the tapped holes for the knock sensors. I think most people find the knock sensor more trouble than it's worth.
Posted: Jul 19, 2006 7:27 PM
by davidu
Do you know what the people running the 745 setup are doing with the knock sensor input if not using it....?Should i resell
the stuff i got and use my stock 533 dme or 535/e34? i already have e28 535 parts car with good dme
Posted: Jul 20, 2006 1:27 AM
by Velocewest
Maybe Ray Avena will weigh in, he was running 535 Motronic on his turbo engine. Don't use a 533 setup, it uses the wrong injectors. The e28 535i gear should work fine.
