turbos
Posted: Aug 05, 2006 5:47 AM
by TurboSnail
i wanted to by a garret t-70 for my 1985 m30 engine . can i spool that turbo properly. what the biggest turbo i can put on my car. i know bigg isnt always best!
Posted: Aug 05, 2006 1:18 PM
by russc
T-70 is way big. Unless your running 600whp, forget it. If its free, well, its still too big...
It will spool like a dog on a M30 engine!
Posted: Aug 05, 2006 1:34 PM
by TurboSnail
ok . well i kinda thought so. they have emm on ebay for $239.00 bucks new. so if any one has a car that can spool that got get yur self one. but how about a t-6 or am i still aiming to big . i have a t-3 turbo thats rebuilt but i think that one would be a little small.
i had a deisle turbo . but i gave it away cus the exaust housing had a few cracks in it. i feel dumb i didnt check it out better but it was a cheap lesson luckly.
umm so recap " what size turbo should i buy" preferably a garrett turbo!
and dose my car have enough displacement to run two t-3 turbos?
these Q's are more of curiosity than idea. but i do think twin threes would look nice under my hood. if it was possible .
Posted: Aug 05, 2006 1:44 PM
by russc
Those sub-$400 turbos on dabay are all cheap chinese knock offs that won't last more than a few years. If you wan't to go that way, be my guest.
Did you look at TCDs website for the turbo he uses, or my site.. those ones are good.
T-3 is pretty small. Yes, you can use two, if you wan't to fab up a custom exhause or try to find an old Cartech unit.
The TO4b or TO4e like TCDs are the right units.
Posted: Aug 05, 2006 1:56 PM
by TurboSnail
ok well i will keep that chines knock off thing in my head when i go on ebay next . yur right on the cheap part i went and looked again. there cheap like you said. so go for a t-4 then an i should be happy. as to the twin 3 Q cant i just bend my header and well a flange on it and bolt my t3 setup to that and run the waste gates linked to one vac line with a T on it and then spen hrs adjusting them? i have a two peice exaust header there iron with steel down pipes. would this be suficent . i saw another bmw at the track built his turbo manifold ths way.
another turbo?
Posted: Aug 05, 2006 4:52 PM
by davidu
is a garrett t3 super 60 ok to use?
Posted: Aug 05, 2006 5:00 PM
by FastFiver
TurboSnail wrote: as to the twin 3 Q cant i just bend my header and well a flange on it and bolt my t3 setup to that and run the waste gates linked to one vac line with a T on it and then spen hrs adjusting them?
HOLY RUN-ON SENTENCE BATMAN!
Jeezus, I have never written that poorly, even when in elementary school. Dude, by being lazy, you come off as an idiot. Take your time and create a post of which we can decipher some information!
(end Shawn D.-inspired rant)
Re: another turbo?
Posted: Aug 05, 2006 6:46 PM
by Brad D.
davidu wrote:is a garrett t3 super 60 ok to use?
Way too small, IMO. Just take a look at the compressor map. Youll be off the right side in no time. Its almost too small for my 2.0l nissan engine. I highly recommend that the original poster go pick up a copy of Maximum boost and read away. Many of the questions being asked will be able to be answered with a little research.
As to making a manifold, I am building a manifold adapter from weld-els. I had a little free time last night and did a quick and dirty mock up for next weekend.
Posted: Aug 05, 2006 7:03 PM
by Boru
I think the duct tape will be fine
T3 flange?
Did you port the exhaust manifolds to match the head now that they're inverted?
Posted: Aug 05, 2006 7:29 PM
by Brad D.
I figured Id just rock the duct tape too. 8) A freind had a blowzilla which, for those that dont know, a Gt40 comp wheel with a t3 hotside. Now I if I hadnt gotten such a good deal on the turbo, id be running a t4 flanged turbo. However, the good news is that its a 76 trim t350 turbine wheel(the largest t3 wheel if I read correctly) in a .82 A/R housing. This should be roughly comprable to a .58 T4 housing, albeit a tad smaller. Well see how it works out.
I do intend to port the manifolds as they done quite match up when iverted. I havent dont it yet, but its on the list of things to do.
Posted: Aug 06, 2006 7:28 AM
by TurboSnail
yea i will try to write better . im not realy all that good at it . so if you could just bare with me please .
Posted: Aug 06, 2006 11:44 AM
by Shawn D.
TurboSnail wrote:yea i will try to write better . im not realy all that good at it . so if you could just bare with me please .
You could've started with that sentence!
To wit...
Yeah, I will try to write better. I'm not really all that good at it, so if you could please just bear with me, I'd appreciate it."
Posted: Aug 06, 2006 11:35 PM
by gol10dr1
jsut so you know, t6 is the flange and not the turbo and anything that has a t6 flange is made to support over 1000 rwhp and isn't even efficient until upwards of 30 psi. so without a $30k built motor, a t6 turbo is useless on a m30 (or any) motor.
Posted: Aug 15, 2006 1:55 AM
by zundfoldge
i went to my local auto yard and got a turbo from a saab 900 i think it was an 88. could any one tell me what the specs on this unit. it has "TB0357" on it . thats ware i got my t-3 some body told me it would work. mabey im the dummy here
Posted: Aug 15, 2006 7:48 AM
by T_C_D
zundfoldge wrote:i went to my local auto yard and got a turbo from a saab 900 i think it was an 88. could any one tell me what the specs on this unit. it has "TB0357" on it . thats ware i got my t-3 some body told me it would work. mabey im the dummy here
Perfect size fro your lawn mower but not your m30.
Posted: Aug 17, 2006 2:51 AM
by zundfoldge
T_C_D wrote:zundfoldge wrote:i went to my local auto yard and got a turbo from a saab 900 i think it was an 88. could any one tell me what the specs on this unit. it has "TB0357" on it . thats ware i got my t-3 some body told me it would work. mabey im the dummy here
how about two t-3 one on each manifold? would that make for fast low psi stable boost pressure? like peak 15psi but steady 9 psi? question of curiosity please dont shoot lol
Posted: Aug 17, 2006 5:24 PM
by Tjn182
twin turbos have shown little to no gain over a single turbo -- plus -- fitting two turbos in the engine bay requires alot more creativity and skill. One turbo, correctly sized -- is all you need
Posted: Aug 17, 2006 6:38 PM
by zundfoldge
Tjn182 wrote:twin turbos have shown little to no gain over a single turbo -- plus -- fitting two turbos in the engine bay requires alot more creativity and skill. One turbo, correctly sized -- is all you need
yes one would be nice and easy wouldnt it. i think im just going to try my t-3 on for size and then later buy my self a hybrid t3 t4 . they mount up the same dont they? flanges , oil , and water lines.?
Posted: Aug 24, 2006 8:04 PM
by Noodles
[quote="Sweeney"]I think the duct tape will be fine
^ im with him it will be fine
