wtb?exhaust studs 745 manifold
Posted: Aug 05, 2006 5:40 PM
by davidu
Does any one know where to get the a set of exhaust studs for 745 turbo manifold for m30 head?easily
Posted: Aug 05, 2006 5:48 PM
by RDAvena
McMaster - Carr
Posted: Aug 05, 2006 6:28 PM
by davidu
wow! they have everything.
what would the technical name for a stud that is 8mm x 1.? to a 10mm x 1.? or does the head have to be drilled and retapped?
Posted: Aug 05, 2006 6:59 PM
by Boru
That would be a "stepped stud" but I doubt you'l find it. Either drill and tap the head for 10mm studs or use 8mm studs with a 10mm x 1mm wall sleave.
Better still, buy one of our manifolds :D
Posted: Aug 05, 2006 9:28 PM
by Tjn182
I keep forgetting the thread pitch... take one of the nuts from your exhaust manifold to lowes hardware and see what pitch it is.
But yeah - McMaster carr has 8mmx110mm studs that you can slap right on. I've had my setup for about 2 years-ish like that with no problems. Tapping the head is too much time and money - - versus $40 in studs.
Posted: Aug 05, 2006 11:13 PM
by davidu
So a longer stud itself will work as opposed to a larger diameter one?
Posted: Aug 06, 2006 9:21 AM
by Boru
he longer stud will hold it but the alignment may not be optimal, hence, the suggestion of the sleaves... a couple would do it.
