Nice weather, about 74 degrees. Only ran 3 runs with some really shitty launches, but still ran a best of 14.336 @ 101.89! I'm pretty happy about that, and with some nice launch technique, I KNOW I can get to 14 flat or maybe even 13.999 on a good day as-is. I had to back out of the throttle a bit too because of wheel hop. Best run occurred at 12:30 am lol....Midnight Drags...
TCD S1 kit running 11psi on a b34 bottom/b35 top end. Felt pretty good tonight. Booker claims that a few people in the stands were impressed with that "white BMW" after a few pulls They kept saying that "it must have something done to it..." I guess they be correct!
Kyle in NO wrote:Nice weather, about 74 degrees. Only ran 3 runs with some really shitty launches, but still ran a best of 14.336 @ 101.89! I'm pretty happy about that, and with some nice launch technique, I KNOW I can get to 14 flat or maybe even 13.999 on a good day as-is. I had to back out of the throttle a bit too because of wheel hop. Best run occurred at 12:30 am lol....Midnight Drags...
Awesome Kyle. Glad you went! Can you post the details from the slip when you awake? Did you shift into 4th gear?
T_C_D wrote:
Based on the MPH it's closer to 250-260rwhp.
Todd
Todd,
That's unpossible. I heard you can get 280 whp easily with a 535is with a chip, port/polish, k&n, and cat-back. I read it here on this forum.
Are you talking with a turbo also, or NA and that equipment.
If NA, Ive yet to see a dyno of a M30b34 worked to the max make more than ~240whp, even with stoker cranks. Now, I haven't seen every dyno either, but Ive seen alot. To be fair, Ive not seen a dyno of a NA stoker M30b34, but Ive/weve heard from people with worked strokers of really disappointing dyno results, but none ever posted any that I can remember. And Id remember a 250whp NA dyno.
