OK smart guys...........water injection question.
Posted: Sep 13, 2006 8:14 PM
by Duke
We all know what the M30B35 intake manifold looks like.
Where should I inject the water into the manifold? Top, bottom, back, front or on the TB side. I am looking for the best location for uniform water/alcohol injection for all six cylinders. I will be using only one injector.
Posted: Sep 13, 2006 8:19 PM
by T_C_D
Intercooler pipe prior to the TB.
Todd
Posted: Sep 13, 2006 8:26 PM
by Duke
T_C_D wrote:Intercooler pipe prior to the TB.
Todd
Is very thin, will need a bung welded to it. I can bring the fitting on Tuesday.
Posted: Sep 13, 2006 10:20 PM
by Jeremy
Just after the exit from the intercooler. Plenty of time for full vaporization of the fluid that way.
Posted: Sep 14, 2006 1:39 AM
by russc
Duke M535ti wrote:T_C_D wrote:Intercooler pipe prior to the TB.
Todd
You'll need to install a bung regardless where you put it. Right before the TB is good. Its unclear how much time the mixture needs to atomize properly. I don't believe you need to put it really far upstream, as energy absorbtion is very fast.
Posted: Sep 14, 2006 8:23 PM
by smackmybutter535i
I heard(just heard i know little about water injection) if you squirt a little windsheld washer fluid into the intake side of the turbo it will supercool the charge air. Is that true?
Posted: Sep 14, 2006 9:51 PM
by Duke
smackmybutter535i wrote:I heard(just heard i know little about water injection) if you squirt a little windsheld washer fluid into the intake side of the turbo it will supercool the charge air. Is that true?
Go to this site -
http://www.aquamist.co.uk/ and do some reading. The cliff notes version is "Design Concept" button.
