RRFPR/FMU choices
FSAEracer03
RRFPR/FMU choices
Post by FSAEracer03 »
I'm looking at both rising rate FPRs and FMUs (vastly different in application, but I have my reasons) and was wondering if you guys know which manufacturers of each make units that replicate the OE Bosch port.
Thanks,
Kevin
russc
Post by russc »
I know of no units that replicate(drop in) to the stock loctation. There is one that says it does, but it is not available yet. There all externally mounted and work in conjunction with the stock unit.
See this thread for the one that in theory replaces the stocker:
http://www.mye28.com/viewtopic.php?t=21 ... hlight=fmu
RussC
FSAEracer03
For the time beig, externally mounted is the only option, got it. Thanks, Russ. That new one looks slick, btw.
Tjn182
Post by Tjn182 »
I dunno but I think this is pretty dandy:
EBAY
russc wrote:I know of no units that replicate(drop in) to the stock loctation. There is one that says it does, but it is not available yet. There all externally mounted and work in conjunction with the stock unit.
I know of one and it is on my engine right now -
$200 from BAVARIAN Autosport - Get more power and better throttle response from your BMW. This adjustable rising rate fuel pressure regulator enriches the fuel mixture as you accelerate to increase power and improve mid-range throttle response. Maintains stock fuel mixtures at idle.
Tjn182 wrote:I dunno but I think this is pretty dandy:
EBAY
Uhh... why is it dandy? It's just an in-line regulator. I don't see how it's "specially designed for the BMW E30 and BMW E28 cars" and the statement "This is nice so it will not hit your hood" is rather curious.
smackmybutter535i
Post by smackmybutter535i »
I have that one, so I don't have to run my cartech RRFPR if I just use the bavauto RRFPR????
russc
Post by russc »
Duke,
That FPR is not a RRFPR as the BEGI unit or Vortech. It doesn't have the capability to raise pressure at an exponential rate, ie more than 1psi fuel pressure for 1psi of boost. The classic RRFPR(or FMU) can be set to raise fuel pressure at more than 1psi/psi boost. So more like 2-5psi fuel pressure per psi of boost.
So Smackybutter, yes, you will need either a BEGI unit or the Vortech unit.
RussC
vance
Post by vance »
We've eliminated (these) problems by linearizing the response of the FPR via friction.
Sounds iffy and unreliable to me. :?
russc wrote:Duke,
Directly quated from the BAV Auto site - "Get more power and better throttle response from your BMW. This adjustable rising rate fuel pressure regulator enriches the fuel mixture as you accelerate to increase power and improve mid-range throttle response. Maintains stock fuel mixtures at idle. "
So are they FOS?
russc
Post by russc »
Duke,
that add is not FOS, it just dosen't tell the whole story. It does rise with pressure, but in a "linear" way, ie, 1psi to 1psi. This is not what you need for a turbo/forced induction setup, where you want a "non-linear" rise of pressure. Say 4psi for every psi of boost!
RussC
russc wrote:Duke,
RussC
From my understanding, that is just fine. 1 psi of fuel for 1 psi of boost. That way the fuel injectors keep up the flow even under say 20 psi of boost. Why is 4 psi per pound of boost needed? I would be over 100 psi of fuel preasure and could pressure lock the injectors. Edumicate me please.
DMNaskale
Post by DMNaskale »
You don't need it, you have big hairy injectors that can keep up with your engine, and a programmable ECU. Little sissy injectors and stock based engine management need the kluge to keep up with the fuel flow demands of higher horsepower than they were designed for.
russc
Post by russc »
So right,
The RRFPR is a cludge, and is for using smaller injs for bigger power. This is usally for non-programmable ECUs, like the stock BMWs. This way you can run boost to ~10psi on a M30 with injs that will still idle OK with a 059 ECU. You can apply this theory to any other car/ECU combo.
RussC
FSAEracer03
russc wrote:Duke,
RussC
To clear up the confusion, I used RRFPR in the barest sense of the term; one that simply rises the rate equal to positive pressure.
FMU I'm using as everyone knows it; a linearly increasing, adjustable (ratio) fuel pressure regulator.
Thanks for all the info guys! Keep it coming in.
AsphaltJungle
Post by AsphaltJungle »
That is the same one I have!
