What plugs are you guys using.
Posted: Oct 16, 2006 10:59 PM
by Lee in Ottawa
Some one recomended i use 1 step colder plugs. I've read this on bfc board as well. What do use M30 guys use?
Posted: Oct 17, 2006 1:18 AM
by gol10dr1
my plugs are ngk bkr8e ix. general rule of thumb is 1 step colder for every 100 hp but when i ran 15 psi i made 350 rwhp (about 170 rwhp more than stock) and had no detonation issues until i hit 16 psi or above. if the plug is too cold you will have start up issues though.
Posted: Oct 17, 2006 9:16 AM
by T_C_D
I always run 3 step colder Bosch plugs and have never experienced any start up issues.
Todd
Posted: Oct 17, 2006 10:29 AM
by Lee in Ottawa
so ngk bkr8e are my best choice or Todd are you saying i should run a colder plug?
Posted: Oct 17, 2006 10:32 AM
by T_C_D
Lee in Ottawa wrote:so ngk bkr8e are my best choice or Todd are you saying i should run a colder plug?
You can try those but I suggest one step colder for low boost level.
Todd
Posted: Oct 17, 2006 5:40 PM
by Lee in Ottawa
anyone know the # for plugs one step colder than the ngk bkr8e ? Thanks
Posted: Oct 17, 2006 5:47 PM
by vance
Posted: Oct 18, 2006 4:28 PM
by Lee in Ottawa
NKG - BKR9EIX $17.98 per cdn.
$122.98 cdn for 6 = $108.23 usd
you guys probably pay $5 each for them
o well
Posted: Oct 18, 2006 4:31 PM
by T_C_D
Lee in Ottawa wrote:NKG - BKR9EIX $17.98 per cdn.
o well
Want me to send you the proper Bosch plug? $40 delivered via USPS.
Todd
Posted: Oct 18, 2006 6:46 PM
by gol10dr1
the plug part from ngk is bkr8e and if you want iridiums you add an "ix" to the end. i have a set of bpr8e2 plugs i would be more than willing to part with seeing as i am broke and in college!
Posted: Oct 19, 2006 12:08 AM
by Lee in Ottawa
Thanks Andrew but just ordered a set from Todd. I hate how everything seems to be sooo much cheaper and more readily available in the states.
Back on topic, i know everyone says use stock plugs in na bmw motors cause i've seen so many complaints about the platinum plugs and such. However i've also heard that iridium plugs are better for boost applications. Now the plugs i'm getting from Todd aren't iridium but i'm still curious do FI m30 guys have problems with iridium plugs?
Posted: Oct 19, 2006 1:59 AM
by Jeremy
I run Denso Iridium plugs in mine. No issues.
Posted: Oct 19, 2006 5:01 PM
by gol10dr1
i ran denso's for a while then when i had the motor rebuilt, the mechanic stuck in a set of bosch platinum 4 prong plugs because "well the e60 m5 uses them and that is pretty much a race motor and so is yours." moron! the plugs were misfiring up top because you can't adjust the gap on 4 prong plugs and it still made 400 rwhp. but now i use the ngk iridiums. my tuner doesn't like them but his dad (also my tuner) recommended them and they have worked fine for me.
