10 psi, whats needed?
Posted: Dec 11, 2006 1:10 AM
by Soco
at 10 psi, on a supercharger or turbo, what is needed?
from what I gather
Intercooler
bigger injectors
some form of fuel management
would I need a bigger fuel pump? ARP studs/new head gasket? would a rising rate fuel pressure regulator work for supplying fuel?
Its not that high of a number, and I was wondering if I can get away with just these things.
Posted: Dec 11, 2006 10:28 AM
by russc
All yo need are:
1) 30lb injs
2) RRFPR
3) IC
Posted: Dec 11, 2006 5:43 PM
by Tjn182
you don't even need the IC -- i've been doing 10psi for 2 years w/o an IC until just recently.
Posted: Dec 11, 2006 6:07 PM
by russc
Tjn182 wrote:you don't even need the IC -- i've been doing 10psi for 2 years w/o an IC until just recently.
Thats on 93 octane, right? On 91, you may not be able to run 10psi non-IC.
Posted: Dec 11, 2006 8:28 PM
by T_C_D
russc wrote:Tjn182 wrote:you don't even need the IC -- i've been doing 10psi for 2 years w/o an IC until just recently.
I ran 18psi non intercooled on 94 octane in 25F temps. Same day car went 109mph in the 1/4. Dec of 2003.
Todd
Posted: Dec 12, 2006 1:38 AM
by russc
T_C_D wrote:russc wrote:Tjn182 wrote:you don't even need the IC -- i've been doing 10psi for 2 years w/o an IC until just recently.
Todd
Right,
That was the magic engine car. Others will vary and will need some IC'ing to do that.
Posted: Dec 12, 2006 2:29 AM
by M635CSi
Todd
What was the elapsed time?
Posted: Dec 13, 2006 12:48 AM
by Skeen
M635CSi wrote:T_C_D wrote:russc wrote:Tjn182 wrote:you don't even need the IC -- i've been doing 10psi for 2 years w/o an IC until just recently.
Todd
Off his site:
60' 2.327
330 6.058
1/8 9.023
MPH 84.28
990 11.447
1/4 13.577
MPH 108.96
Posted: Dec 13, 2006 1:00 AM
by Jeremy
russc wrote:
Right,
I run 10psi non-intercooled with a fairly large safety margin. Never pings or knocks, even at full boost on a very hot day after being stuck in traffic.
All that's needed to accomplish this is non-cali-craptacular formula 93 octane fuel.
I would highly recomend an oil cooler though.
Posted: Dec 13, 2006 4:56 AM
by 90e34535i
i ran 10 psi non intercooled with 91 octane for while with no detonation.
I had it at 14-15 psi (got sent wrong spring) non-intercooled for the first 2 weeks after I turbo'd my car.
It felt realy fast(especially before I got the exhaust put on), but had slight detonation at peak torque every once in a while in the Higher gears(3rd,4th,5th). At the time I also was running out of fuel, not being able to keep it very rich, was jumping past 110% duty cycle.
I think if I could have retarded the timing and had enough fuel, I could have ran 14-15 psi non-intercooled with no detonation on 91.
Posted: Dec 13, 2006 8:50 AM
by Tjn182
Jeremy wrote:russc wrote:
Right,
Ooooh yeah an oil cooler. Man... you gotta have one of those.
Posted: Dec 13, 2006 10:13 AM
by russc
90e34535i wrote:i ran 10 psi non intercooled with 91 octane for while with no detonation.
Mmm,
My current M30b35 will TCD chip only runs to ~8-9psi on Chevron 91 here in the SF Bat Area. After that its major pre-det.
Am I missing somthing?
Posted: Dec 13, 2006 10:40 AM
by Boru
russc wrote:90e34535i wrote:i ran 10 psi non intercooled with 91 octane for while with no detonation.
Mmm,
You're running rich even in cruise, could be carbon build-up. Lots of variables to consider like fuel quality, casting imperfections, timing, etc.
Posted: Dec 13, 2006 10:53 AM
by russc
Ya,
Its runs rich, but not horribly rich. There is probably differences in the turbo package. The TCD manifold/turbo are most likely more efficient than the old Dinan package. That can lower temps a bit!
And, I never checked the condition of this engine on install. Who knows whats in there. But it did make 325whp, so it can't be that bad.
Posted: Dec 13, 2006 11:09 AM
by M3fan4eva
What about adjusting the fuel pressure? Would that solve your problem?
Posted: Dec 13, 2006 11:14 AM
by russc
M3fan4eva wrote:What about adjusting the fuel pressure? Would that solve your problem?
Its not that simple. The ECU is runing closed loop. It should adjust inj duty cycle to compensate for lower pressure. Its somthing that may have to get fixed by other means. Not sure what those means are yet.
Posted: Dec 13, 2006 3:53 PM
by landspeed
don't forget cooler spark plugs for added safety.
