Geeking Out
DMNaskale
Geeking Out
Post by DMNaskale »
In the fine tradition of how I used to spend the day after Christmas as a child, I woke up way too early today and decided to amuse myself by taking something apart. Since I didn’t get any presents that lend themselves to disassembly, I decided instead to look under the skirt of the Electromotive TEC-3r that is currently employed as an ornament on the parts shelf. To my untrained eye it looked nice. It sports one PCB covered with SMDs, and a bunch of transistors firmly attached to both sides of a heatsink, which screws directly to the beefy outer housing extrusion once the board is slid in. Conformal coating all over everything, big sealed AMP connectors for the 2 main harnesses , a Weatherpack connector plug on the main power pigtail, and a stoutly mounted 9 pin d-sub for the serial to laptop connection. It also sports one jumper wire kluge, which is not too bad I suppose.
I just took the numbers off the more important looking chips and did a quick google on them for a device description. I am in way over my head on this thing, if any of you genuine electronics guru types want to comment, it would be very interesting to get some feedback on this piece of hardware, and how it compares to the other options out there, including the MS and MS2.
TEC 3r top view
TEC 3r side view
TEC 3r bottom view
Motorola 8-bit 4MHz microcontroller
MC68HC11KW1
CPU4
2F71B
QQAA0247
(2)Microchip 8-bit microcontrollers
PIC17C756A
331/PT
03462RB
ATMEL complex programmable logic device
ATF1504AS
10AC44
0334
ST 128KB flash memory
PSD813F2A
-90MI
5BS6R0350
(2)Motorola automotive quad low side drivers
MC33385DH
KAR0351
dual motor driver
A3976KLB
a 0319
M319318BPA
RS-232 driver
ADM232AARW
0407
393240.1
Philips PLL
HEF4046BT
AK052 02
Un604184
(3)TI dual flip flops
9ADXJEK
CD4013BM
(2)TI quad gates
41D1CFK
CD4081BM
(2) quad comparators
PM39AS
LM2901M
Re: Geeking Out
DMNaskale wrote:In the fine tradition of how I used to spend the day after Christmas as a child, I woke up way too early today and decided to amuse myself by taking something apart.
Ah, I know that pastime quite well!
Yellow2
Post by Yellow2 »
I do that every day, regardless of xmas or not :)
altus22
Post by altus22 »
Pretty nice looking. Epoxy encapsulated. I'm kinda jealous...but not really. MS!
