the e34 engine bay might be big enough. to make double sure - you could always get a passenger's side 533i mount + M5 rubber mounts -- that'll get you the clearance fo' sho'
Tjn182 wrote:the e34 engine bay might be big enough. to make double sure - you could always get a passenger's side 533i mount + M5 rubber mounts -- that'll get you the clearance fo' sho'
533 engine mount doesn't work with the m30b35 engine.
