Will be cutting the six fuel injector wires from the TEC3 ECU and installing the connectors today. This will allow the Traction Control ECU to be connected to the fuel injector wires and also allow the TC ECU to be removed from the fuel injector signal if it goes bad.
Connector is installed and the engine works properly.
Step 1 complete.
Now I need to make a panel that will go where the ash tray is that will house the TC Digital Adjuster control head and A/F ratio meter plus some switches.
