Will have TCD S1 running today.
I just wanted to ask one question.
I am trying to decide where I want to hook up the wastegate boost signal.
Should I drill and tap the intake manifold or ;
Should I drill and tap the compressor housing outlet?
What are the potential plus/minus' to doing each. Are there any performance or drivability issues associated with the different locations.
Thanks for any and all input.
For an intercooled system (which I realize Greg doesn't have right now, but Duke does), isn't it better to get the wastegate signal from somewhere after the intercooler? I thought the pressure drops as the charge cools through the intercooler, making the intake manifold the best place to get the wastegate signal from.
Greg, in my case I got the signal from the intake manifold, but I left the vacuum line to the interior temp sensor disconnected so I didn't tap a new fitting. This hasn't seemed the affect the way the HVAC functions in the least.
Like I said, it doesn't really matter.
Let's assume everything is accurate... If you have a 1 bar WG spring signaled off the compressor and you have a boost gauge signaled off the manifold then the gauge will never quite reach 1 bar due to the pressure drop between the compressor and the intake manifold. If the signals originate from the same location then, in a perfect world, the gauge will read 1 bar boost. We are talking about a small difference in pressure in a well setup system... 0.5-1.0 psi or so.
I always tap off the manifold.
IMHO, you should not use that tap. Now, I know its not very likely, but what if the bolt comes loose, and that tap falls into the intake system? Especially if its after the IC! Using a welded tap somewhere is the most correct way to go. Just added insurance.
RussC
RussC
Duke M535ti wrote:Drill neither.
Install on of these in the fitting between the turbo and the intake pipe.
Clikcy
Be be aware that they charge more for shipping (1st class) than the fitting itself. Complete BS.
Doh, I didn't see the locking mechanism at first. Thats definatley a better tap than I though.
russc wrote:IMHO, you should not use that tap. Now, I know its not very likely, but what if the bolt comes loose, and that tap falls into the intake system? Especially if its after the IC! Using a welded tap somewhere is the most correct way to go. Just added insurance.
RussC
Clikcy
Car is running excellent so far. I ended up tapping the compressor housing because I didn't want to remove the intake manifold and the turbo was still off the car at the time.
I will be installing my B35 intake soon enough and I will make certain to put a few extra ports in it prior to installation.(yes I already have the B35 head installed).
As soon as I have time to sort through the pictures I will post some of them up. Bye for now.
OK,
Ill play, doesn't the clamping force of the washer against the fittings back washer give back the structural integrity that was lost by drilling?
RussC
RussC
Sweeney wrote:I wouldn't use it because;
1; it's very easy to just drill/tap for a threaded fitting.
2; punching a hole in the connector cuts the fiber reinforcment imbedded in the silicone.
No, it wouldn't because the whole structure around the insertion point is affected and can create other issues. If something is designed like that, you don't mess with it. Metal is a different story, which is why the compressor or manifold was probably a very good place to put itrussc wrote:OK,
RussC
When it fails and you overboost and blow your motor, will you tell us?Duke M535ti wrote:Yep, I there with you brother. In fact, I have one installed and sleep quite well at night too.DMNaskale wrote: The burst pressure of a typical hose is a couple of hundred psi, it seems very unlikely that one of these taps could cause any problems at 10-20 psi on a street car.
IMHO is very lazy way to do it and a totally unecessary risk. But hey, what do I know?
Never happen. The signal for the waste gate is from the manifold via a stainless steel line that you installed. The pressure from this fitting goes to the EBC solenoid.T_C_D wrote: When it fails and you overboost and blow your motor, will you tell us?
IMHO is very lazy way to do it and a totally unnecessary risk. But hey, what do I know?
Speaking of lazy, how about you answer my PM reference the heat exchanger.
Me too but it is a real PITA to call out from here.T_C_D wrote:You want something quickly than call me on the TELEPHONE!
I hate PMs.
Now just to clarify things. This would not be the best thing to use for the waste gate control. It is perfect for what I am using it for, and electronic boost controller signal to the solenoid.
I would also only use a stainless steel braded or hard line for the signal from the manifold to the waste gate for the utmost fail proof safety.
Myspace is a good way to communicate!M635CSi wrote:I've heard tell of something called "text messaging" but it seems farfetched...GregATL wrote:Sweeney wrote:There's this new thing called "electronic mail" or "e-mail".I have no idea what you are referring to.
Electronic mail, what'll they think up next?:dunno:
![Laugh :laugh:](./images/smilies/laugh2.gif)
Why would yourspace be preferable for communication.BadM535i wrote:Myspace is a good way to communicate!M635CSi wrote:I've heard tell of something called "text messaging" but it seems farfetched...GregATL wrote:Sweeney wrote:There's this new thing called "electronic mail" or "e-mail".I have no idea what you are referring to.
For that matter what exactly is "yourspace"
It’s what Al Gore invented after the internet...GregATL wrote:Why would yourspace be preferable for communication.BadM535i wrote:Myspace is a good way to communicate!M635CSi wrote:I've heard tell of something called "text messaging" but it seems farfetched...GregATL wrote:Sweeney wrote:There's this new thing called "electronic mail" or "e-mail".I have no idea what you are referring to.
Some would say he was waiting for himself to invent the internet first so he could release his new creation. Right before he invented the hybrid and clean air.M635CSi wrote:It’s what Al Gore invented after the internet...GregATL wrote:Why would yourspace be preferable for communication.BadM535i wrote:Myspace is a good way to communicate!M635CSi wrote:I've heard tell of something called "text messaging" but it seems farfetched...GregATL wrote:I have no idea what you are referring to.
Explained perfectly except you forgot one little thing,theseeker411 wrote:Myspace.com - a website dedicated to teens with way too much freetime and a low desire to interact with the physical world; where one can create an online identity, communicate with friends, spill their guts on their blog, discover new music, blah blah blah. Mildy entertaining in small doses.
![Alright :alright:](./images/smilies/alright.gif)
