Dinan M5 turbo on the bay!!
http://cgi.ebay.com/ebaymotors/Dinan-BM ... dZViewItem
So I'm the high bidder on this what do you guys think?
I would not touch it with a 1000' pole.
Used pistons, used (nasty) turbo, used everything. Is the manifold cracked? Is the turbo serviceable.......how is the crank?
Without having a competent shop check all the parts, you may end up with a box of junk.
I have learned myself that used unchecked parts could easily cost you more than new parts.
If all of this was $500, then maybe………$1500+, no way.
The seller has been on ebay since Nov 06 and only has two feedbacks. CAUTION.
I am not saying the manifold is cracked. Without a shop testing and checking the parts, I do not see how they can be sold as in "excellent" condition.turbodan wrote:I'd buy it. Theres no reason for the manifold to be cracked. I bet the crank is fine too. If the turbo is cooked, replace it. Doo eeet.
I am not willing to assemble and engine on a "I bet" condition.
If I had to guess I would start here: http://www.mye28.com/viewtopic.php?p=22 ... ht=#228073Duke M535ti wrote:OK, you gotta fess up with what you know.johnnye23 wrote:Guys look who the seller is and do your homework. Once bitten twice shy here. Johnny
Vance
- Beamter
I'm a little scared because of this guys low feedback score. Then again I have a low score and I'm an honest guy. Is there anybody down in georgia that could check this stuff out for me before I drop $1500? If not that, I know some non-car people down in Atlanta that could hand deliver the check so at the very least I'm getting parts, and not just giving money away.
If it is as he says though.....what are your thoughts on this setup? Seeing that the turbo is junk, should I rebuild or is there something newer I should go with instead? Also this is gonna have to be a fall/winter project, as I'm going to have to buy some more parts and save some more money.
If you're having second thoughts you could always retract your bid. $1500 seems steep just for a used S38 manifold. Is that what these go for these days?
On the M30 front, you see all these Dinan, Cartech, and 745i used turbo kits out there, some in better shape than others. Yes they're cheaper than a TCD kit. But if you go with a TCD kit you get new parts, more than just a manifold & turbo, and support. If you have a problem there's someone there to help weather it's for parts or advice. By the time you're done pieceing together a kit, you could have bought a new complete one.
That's what I think of everytime I see a turbo kit cheap out there and the wheels start turning. Then I calm down and got back to saving for a TCD kit. I'd love to turbo a S38 but S38's don't like me. I've had bad experiences with them. That's why I stuck with a M30. They're cheaper, simpler, and they like me.
Congratulations on being the highest bidder… What I think is that you shouldn’t have posted this on the mye28.com board…BMWS38 wrote:http://cgi.ebay.com/ebaymotors/Dinan-BM ... dZViewItem
Duke, in good faith, I think the owner of that turbo engine would have serious reservations about selling it to someone who can’t even get a two valve tractor engine to run for more than a season without breaking down.Duke M535ti wrote:I would not touch it with a 1000' pole.
The reason the parts are “(nasty)” and “used” is because the engine was actually reliable and held together long enough to get some mileage…Duke M535ti wrote:Used pistons, used (nasty) turbo, used everything.
Nope the manifold it fine; a testament to the genius which is Steve Dinan.Duke M535ti wrote:Is the manifold cracked? .
Yup but as it says in the auction, rebuild it anyway. FYI, an ellipsis is a series of three consecutive dots, not seven.Duke M535ti wrote:Is the turbo serviceable.......
The crank is fine. Runout and journal specifications are within tolerance. It should be polished though.Duke M535ti wrote:how is the crank?
No, your judgment is, once again, flawed.Duke M535ti wrote:Without having a competent shop check all the parts, you may end up with a box of junk.
When did you learn that?Duke M535ti wrote:I have learned myself that used unchecked parts could easily cost you more than new parts.
The fact that you think those parts fair market value doesn’t represent over $1,500 is more a sign of your knowledge and experience than it is an appraisal of those parts. Again, an ellipsis has three (…) not seven, eight or any other random number of keystrokes that fall from your keyboard.Duke M535ti wrote:If all of this was $500, then maybe………$1500+, no way.
That point should certainly be taken into account and bids discounted accordingly. Unfortunately, a discounted bid won’t win the auction.Duke M535ti wrote:The seller has been on ebay since Nov 06 and only has two feedbacks. CAUTION.
Thank you for that vote of confidence turbodan. Your comment is significant because it comes from someone who has successfully rebuilt their engine and turbocharged their carturbodan wrote:I'd buy it. Theres no reason for the manifold to be cracked. I bet the crank is fine too. If the turbo is cooked, replace it. Doo eeet.
They are being sold as in “excellent” condition because they are in “excellent” condition. The fact that you do not know how to check an engine is completely irrelevant to the fact that other people do. And it doesn’t take a shop full of machine tools to do so.Duke M535ti wrote:turbodan wrote:I'd buy it. Theres no reason for the manifold to be cracked. I bet the crank is fine too. If the turbo is cooked, replace it. Doo eeet.Duke M535ti wrote:… Without a shop testing and checking the parts, I do not see how they can be sold as in "excellent" condition.
How many engines have you assembled?Duke M535ti wrote:I am not willing to assemble and engine on a "I bet" condition.
Correct. These parts should be fitted together by a competent mechanic, preferably someone with experience in both turbocharging and engine building/machine work on an S38 engine. As was stated in the auction, this isn’t a project for the novice.turbodan wrote:I certainly wouldn't just stab it in there either. I know how nasty used turbo parts can be. But I would buy it.
Yes Johnny and that is why the seller didn’t post the parts for sale here. He’d been bitten once by someone on the board who took his money under, what looks in retrospect to be false pretenses. That person continues to retain the money without delivering on his obligation, retracting his statements or issuing an apology. It’s not surprising the seller didn’t make it available to the mye28.com “community”.johnnye23 wrote:Guys look who the seller is and do your homework. Once bitten twice shy here. Johnny
Well, I know who the seller is and I know the condition of the parts.Duke M535ti wrote:OK, you gotta fess up with what you know.johnnye23 wrote:Guys look who the seller is and do your homework. Once bitten twice shy here. Johnny
Good guess!vance wrote:If I had to guess I would start here: http://www.mye28.com/viewtopic.php?p=22 ... ht=#228073Duke M535ti wrote:OK, you gotta fess up with what you know.johnnye23 wrote:Guys look who the seller is and do your homework. Once bitten twice shy here. Johnny
Vance
Thank you TCD. For the person who wants the reliability of a cast iron turbo manifold on their S38, this is the only game in town at the moment. At $3,000 it would still be the only way 99% of enthusiasts could get a cast iron turbo manifold for an S38 engine and it still wouldn't be an original Dinan unit.T_C_D wrote:The manifold is worth $1500 to the right buyer. Seller is M635csi. I believe he paid $2500 for the parts off ebay last year.
Martin in BellevueWA, that just means you lack intellect in one of many realms. FWIW, I was the one who got screwed on the deal you’re referring to, the other person got money they weren’t entitled to from me. I didn’t want to do business with them and gave them money for their agreement. To this day, they haven’t honored their agreement or returned my money. The fact that your intellect is not only limited to a lack of imagination but also lacks basic understanding regarding the rules of engagement in business is not surprising.Martin in BellevueWA wrote:I cannot imagine anyone on this board would take a chance with dealing with m635csi.
The buyer will bid significantly more than $1,500 to win the auction. Beyond that, depending on what you want determines what you do. A hybrid GT35R was slated for the install but that may not fit your goals. Suffice it to say, getting over 500 hp out of that engine is a walk in the park for anyone that knows what they’re doing.BMWS38 wrote:I'm a little scared because of this guys low feedback score. Then again I have a low score and I'm an honest guy. Is there anybody down in georgia that could check this stuff out for me before I drop $1500? If not that, I know some non-car people down in Atlanta that could hand deliver the check so at the very least I'm getting parts, and not just giving money away.
$1,500 for just the manifold would be quite the deal. Unfortunately, that deal isn't available.
I heard a rumor if the Dinan turbo doesn’t sell on ebay then its going on a 745; just a rumor though…
On the other hand...
745 turbo setup on the bay - something from a more reputable seller. No affiliation, etc.
(Frank, stop poking the monkey!)
That's cute "filmy" but if you learn a little about BMWs you'll find the "745 turbo setup on the bay -" won't fit the S38 engine.filmy wrote:On the other hand...
And while you're blowing me, "M635CSI", you can ask yourself, "Did Filmy actually say that turbo setup would fit an S38 engine?" Everyone else, of course, already knows the answer. Now get to work - you have pointless, over-protesting essays to write! For awhile there, I thought we missed your educational and informative posts. And then it hit me while reading your diatribe to Duke above - "nawwww..."M635CSi wrote:That's cute "filmy" but if you learn a little about BMWs you'll find that won't fit the S38 engine.filmy wrote:On the other hand...
That's cute "filmy" but if you learn a little about BMWs you'll find that won't fit the S38 engine. [/quote]M635CSi wrote:(Frank, stop poking the monkey!)filmy wrote:On the other hand...
I gave you the benefit of the doubt between being ignorant and not having the ability to reason. It would have been easier for you to learn the difference between BMW parts than it will be for you to learn rational thought. The point being you are irrational to suggest, and suggest you did, a part for someone's car that you know will not fit their car. It would have been better to accept your technical ignorance than to reveal you're irrational...filmy wrote:And while you're blowing me, "M635CSI", you can ask yourself, "Did Filmy actually say that turbo setup would fit an S38 engine?" Everyone else, of course, already knows the answer.
That's the difference between us; I don't even notice when you're not here.filmy wrote:Now get to work - you have pointless, over-protesting essays to write! For awhile there, I thought we missed your educational and informative posts.
filmy wrote:And then it hit me while reading your diatribe to Duke above - "nawwww..."
At least we can agree you deserve to be hit.
You've identified yourself as lacking imagination. Whether you’re also irrational is a separate question; it wouldn't be a surprise to learn that you are both irrational and lacking imagination.Martin in BellevueWA wrote:So everybody but m635 on this board is irrational & lacks imagination?
No but it is quite often the ones who promote themselves as speaking for a group they don't represent.Martin in BellevueWA wrote:Is it always everyone else, m635?
