Fort those running JE pistons, how much did you overbore for 92.5mm pistons? Basicly piston to wall clearance.
JV
JE pistons
JE recommends 0.0035"-0.0045" wall clearance for this size piston. I'd go right in the middle, 0.0040" for FI. Remember, JE forged pistons have a heavy taper from crown to skirt. There is almost 1mm difference in diameter from crown to skirt on my JE pistons. 1/2" up from the very bottom of the skirt is standard spot to measure the pistons diameter.
