Brake Booster Woes? Sortof OT...
griffith
Post by griffith »
I am curious if anyone here has a car that uses a standard vacuum brake booster. If so, did you find that you needed to update the check valve in order to accomodate the boost pressure? I'm guessing that if the OEM brake booster check valve fails, it will be short life for the booster itself.
I know the e28's all (or a majority at least) run the hydraulic brake assist systems, so this is a bit off topic, but any help would be appreciated.
I'm also curious where else check valves are commonly used in the l-jet and/or motronic systems where they may not have existed prior to turbocharging.
Thanks again,
Jason
All M20 e28's use the vacuum booster. There are probably more 528e's out there than 53x cars. So really the majority probably uses vacuum boosters.
Anyway, I'm using the stock check valve system in mine, and I have no problems. The check valve normally does not allow boost into the booster itself. The booster holds a vacuum, so wether its boost pressure or just atmospheric pressure trying to get in, the check valve should prevent boosting the booster. I guess if it failed it could damage the booster. I'm sure it wasnt designed to hold positive pressure.
griffith
Post by griffith »
Ahh, interesting. I'm really just curious what the breaking point on the check valve is in terms of boost. Mine appears to have broken and it took the booster out with it. I'd prefer to fix it right rather than to use a stock check valve if there is a necessity for that. For all I know the stock check valve may have failed for another reason though.
Jason
I dont think it has a real limit as far as boost. It might not take 50 psi, but realistically theres no way youre going to boost that high. I'd just use a stock replacement and not worry about it.
griffith
Post by griffith »
Excellent. Thanks much. I'll let you know how it works out.
Jason
Cool. I'm running around 15 on mine, I'm sure it spikes a bit higher on upshifts until the bypass valves oven up, and its been fine so far.
