My 535is Turbo Buildup Thread! - update 11/26//09
Well, I decided years ago that I would own a turbo BMW. I never quite wanted to buy a kit ( partly due to the initial cost, partly because I love to do it myself) so I set out on making my own setup.
The platform is my '87 535is which I have owned since '99. I originally bought a bunch of 745i parts but ended up selling them to help fund my turbo 240sx project. About 2 years ago I installed a m30b35 and all of the associated wiring. Unfortunately Motronic 1.3 does not take well to being turboed. I would later find a solution for this.
Here's another pic of the car (11/'08 ).
With new Spax suspension 12/'08
While all of my fabrication isn't quite complete I wanted to start a buildup thread to outline my work so far and add to it as I go.
I have boxes of parts and pretty much everything I need to make it happen has been purchased. Everything else I have made.
I fabricated my own manifold adapter out of weld-els.
The center tube is for my 38mm Tial WG. The stock manifold will be flipped and have been gasket matched to the head. You can sorta see the WG mounted during mockup.
Turbo has a GT40 compressor wheel in a .50AR housing. Turbine is a T4 P-Trim wheel in a .84AR Euro T4 housing (has a T3 footprint).
Function 7 oil flanges and -4AN oil feed line.
Installed
I decided that I wanted to run a front mount IC. While it is possible and fits very nicely behind the factory IS airdam, major valance trimming is required.
IC piping installed.
Thats where I am currently. I have a box full of 3" mandrel bends to build my downpipe and a new exhaust with a Magnaflow muffler and cat which shoul show up this week.
As for other items that are of importance I will be running 42lb/hr injectors and have already finished building my MS2 and a Glens Garage idle board. I still need to finish my Motronic adapter harness but that shouldn't take too long to finish. While its got a ways to go I am past the point of no return and am confident that it will be a success and look professional when it is completed. I would love to hear everyones comments and feedback.
Installed
Great project! I love to see this kind of project. Over 6 years ago I was attempting to do the same with my 535is. There was almost no useful information available on the internet and hardly anyone that even had a turbo e28. Those that had were not sharing information (except for RussC).
Currently there is a wealth of information (mostly good), that makes this kind of project more achievable. As a DIYer, I appreciate the shared knowledge of this board.
Good luck.
Good luck.
Thanks for all of the complements guys. This board has a wealth of knowledge, especially regarding forced induction and has proved to be an invaluable resource.
Well, the engine and engine bay were clean when I swapped it in almost two years ago. I'll clean it all up when Im done mocking everything up.One question though...if you had that engine comepletely OUT of the car before the swap, why not clean it a little???
It seems that it works out great. I gasket matched the manifolds ports but overall it works out suprisingly well. They are a direct fit if flipped - no bolt hole elongation of mods required. Maybe not the most elegant solution, but I still think it turned out ok and is very functional, strong and should work well. Best part is cost about $50 for all of the weld els and the turbo flange. I made the other three bolt manifold flanges.How did the flipping the manifolds go? Did they line up alright or did u have to massage the ports, elongate the bolt holes a bit? That is a great idea congrates!
Like turbodan said, I don't think there would be all that much to be gained by changing the piping. I have entertained the idea of machining the "back" side of the intake mani to accept the throttlebody for a straighter shot, but thats for another day. I just want to get everything up and running first.Question....dont take offense but I wanted to know if it would be better for performance to cut the intake manifold on the other side so that you dont have those extra bends going to the throttle body?
666fab did something similar with the M20, didn't flip the manifolds though.
My 535is Turbo Buildup Thread! - Update 10-6-07
Progress Update -
Had a little time today to begin working on the downpipe. Its 2.5" out of the turbo transitioning into 3" all the way back. I'm pretty proud of it. I still need to add the wastegate return but now that its where it is, that should be easy. Tomorrow I should finish it up back to the cat flange and get the wastegate dump plumbed in.
Here is how the wastegate mounts. The dump will be straight shot right into the downpipe (don't mind the coil wire).
It is fairly close the the ac lines, maybe half an inch at the closest point. The downpipe will be wrapped as well as some thermal barrier sheething around the lines, I just havent installed it yet. I also have turbine blanket tha will be installed to keep underhood temps down. As for the rear plug, you cannot use the factory tool. I used a thin wall socket and a ratched and, while tricky (you can't back it all the way out with the ratchet still on the socket), it can be removed with the exhooassed in place . Its not perfect, but its still less comprimised for plug acess or a valve adjustment than an m20 with a 524td manifold and a big turbo.
The downpipe is 2.5" and it transitions into 3". The turbine exducer bore is just under 2.5". I wanted to do a conical transition as I have read this helps flow expansion exiting the turbine, but I didn't want to pay $30 for one cone transition so I just swaged some 3" pipe down to 2.5" in the bender.chrism wrote:How big is the outlet of the turbo? is it 2.5 or 3?
I think thats what im going to do, just bypass the cooler all together. It will clean things up and its one less thing to worry about.Kyle in NO wrote: You'd better bypass that AC line fuel cooler, those rubber hoses are gonna cook! Awesome buildup BTW!!!
Well, I made more progress this weekend, but I didn't take any pics. I'll get around to getting some soon though as everything is coming together nicely. I got my turbo oil drain in the oil pan drilled and tapped. I got the wastegate dump plumbed into the downpipe. I also fabbed up an inlet pipe with a fitting for the bosch bypass valve I will be using. I also plumbed the IACV back into the IC piping so I can have idle control. Its down to all the little nitty gritty details now. I still need to drill my oil filter block for my oil feed, fab up my exhaust, heat wrap stuff, paint things, install MS and add a few wiring circuits. No sweat! 8)
just curious... how much are you looking at spending total doing this project yourself??? I would love nothing more than to be able to do a project like this... and i know it would save me money.. it's just i would have to learn how to weld first!! which right now i'm a little too busy for... haha
Well, I've been keeping a loose record of what everything has cost and right now I've spent close to $1700. There are a few more incidentals that I will inevitably buy, but I would say that I will spend around $2k when its all said and done. Mind you some of the little stuff was cheap or free and I did all of my own fab work throughout the project.
