Hello All,
I'm going to attempt to post some pics of my latest occupations. I'm building the bottom end of my e28 m5 m88 Turbo. The crank was knife-edged and was reduced by 10 lbs. I'm using custom JE pistons. It is 94mm bore x 86mm stroke to bump it to 3.6 liters. Everything has been balanced individually down to 0.5g, then balanced together.
I also recently completed the e9 2800cs m30b35 turbo project. I will eventually post more pics which will be better quality. Here is a shot under the hood. This was a couple weeks before I really finished it up.
Pics
http://briefcase.yahoo.com/jesseohara
More to come later...
Thanks for looking!
-Jesse
M88 Turbo and M30B35 Turbo
E9 turbo Project
I'm sure the lads on www.e9coupe.com would love to hear about your 2800CS Turbo project....
very nice !.., who did the crank work ? And I assume this is a e34 crank ? M5 or 535 ?
I have an M5 crank, 86mm, that is stock but would love to knife edge that baby. Although I heard that by removing the counter weight you loose that high speed smooth cruise on the freeway. What do you know ?
Look forward to to your reply.
Philo.
88M5
Philo.
88M5
Castillo Crank Service of La Mirada, CA did the work. I have seen their work in multiple magazines and I talked with the owner. They seem reputable. Yes, it's an m30 crank, which is how I got from 84mm to 86mm stroke. I'm excited to see how this turns out with -10lbs. off the crank. I'm in the process of building a SS top-mount manifold. Woohoo! ![Banana :banana:](./images/smilies/banana.gif)
