The M5 - Before and After Detailing
Looks good. Certainly a big improvement! What was that, salt or sprinkler spray all over the car?
BTW, you can repaint the old taillight black trim and have it match the new one. Very easy. Also, it looks like they forget to put dressing on the front grilles. There is really nothing worse than faded black trim against shiny black paint!
But yours are so faded that it will likely be a never ending process of spritzing the stuff with dressing, so I'd probably recommended painting them or replacement. There are also some black dye products that you can use (only last 3-6 months), but the grilles are a PITA due to all the multi-faceted surfaces. As far as painting, many folks have had good luck with the SEM line of products.
Beautiful car!Justin_FL wrote:Looks good. Certainly a big improvement! What was that, salt or sprinkler spray all over the car?
I repainted my grills with Rustoleum Satin Black. It's got a wee bit of shine and looks great. Took a while to get every little nook and cranny though.
That's simply AMAZING ! lots of work though.
Now that you have a good base surface a bi-weeky car wash yields great results. Another thing I do is use glazing compound with a buffer ever 6 months or so. It really pulls out the rich black shine. That wet look.
Question.. what did you use on the aluminum in the engine compartment ?
Change the coolant tank to a new white plastic one and it will complete the pristine appearance on the engine detail.
Great job !
Great job !
The guy used Meguiars Hyper Dressing in the engine compartment (it's water rather than silicon based). It's actually not as shiny in person (guess the camera flash brings it out).
I have a set of euro headlights and grilles coming, so that should resolve the dead plastic issue up front. As for the rear taillight, I definitely don't want to drop $276 on a new assembly from Maximilian...guess I'll look into repainting.
The water spots - yeah that was from my irrigation system before I cleared out my garage and could park inside...
Re:
Hi E28M5 SubDriver, you did a great job in your garage, please tell us what methods you used to remove these stains. I have worked in the car detailing business for a long time, and I know how difficult it is sometimes to remove a bunch of these stains, especially if you delay it and postpone cleaning for several months.
Re: Re:
You do realize this thread is 13years old, right?Cashantony wrote: Jul 30, 2021 4:43 AM Hi E28M5 SubDriver, you did a great job in your garage, please tell us what methods you used to remove these stains. I have worked in the car detailing business for a long time, and I know how difficult it is sometimes to remove a bunch of these stains, especially if you delay it and postpone cleaning for several months.
Or are you just trolling for your business?
