E24 Turbo Eye Candy (56K beware) UPDATE!
John In Valdosta
Post by John In Valdosta »
The was on the Roachfly 6-series board. It belongs to Juliab Seager in Australia. He's been working on it for a while now and has been posting updates and pictures. I'm not sure but I think it's just and Alpina Intake valve cover and body kit on a regular six. He even has a rear AC unit that mounts under the rear parcel shelf, it's probably aftermarket but it's pretty cool for sure (that's another set of pictures though).
I could do without the gold trim. Notice the power steering assisted brakes have been removed. The Coolant catch can has been moved and replaced.
Here's the link http://bimmer.roadfly.org/bmw/forums/e24/6292352-1.html
Julian posted his pricelist over the weekend thought I'd share:
http://bimmer.roadfly.org/bmw/forums/e24/6301573-1.html
2nd hand 1989 model 3.5 litre engine $1500
Alpina head FREEBIE
MoTeC M800 ECU $3530
Wiring loom & sensors $490
Boost controller $70
2nd handNissan 300ZX coil igniter $200
Intercooler $1200
Turbo, BOV, Actuator & fitting kit $3900
Fuel pump, rising rate fuel reg & filter $1085
6x Bosch coils $200
Exhaust manifold $1100
2nd hand late model 735 intake manifold $100
ROSS forged pistons, rings & gudgeon pins $1150
6x 750cc Siemens injectors (from TCD) $830
Fly wheel sensor $90
Exhaust & intercooler piping $1400
Silicone pipes and hose clamps $600
Competition coatings (porcelean coating) $700
Camshaft $700
Clutch plate $175
Various engine rebuild gaskets & components $1700
Various machining & fabrication $1800
Idle control valve $120
K&N air filter $93
Braided lines & fittings $1000
Iridiam spark plugs $130
02 sensor $387
1mb Data logging $270
Lamda upgrade $880
More sensors & plugs $280
Ignition leads $200
Various hose insulation sleeves $180
ECU programming $400
Engine assembly Freebie
TOTAL COST THUS FAR $26060 approx
[Edit by John In Valdosta on [TIME]1110150925[/TIME]]
Fantastic detail in the engine compartment................I like and can appreciate it. I dont like the Lexus looking gold inlay on black though. Gold door handles make me want to hurl.
This thread would be better in the "Forced Induction" Forum.
It appears as if the brake boost has been switched to the left side, away from the right side and converted to vacuum boost. I wonder how it's actuated -- cables, or linkage?
The plate holding the vacuum/boost, ICV, and throttle cable is a neat setup -- a neat solution to where to mount them all and block off the old throttle hole at once.
shifty
Post by shifty »
Awesome shark, for sure. That kind of engine compartment takes plenty of work!
fastpat
Post by fastpat »
Very nice, full control of ignition for each cylinder too, very complex. Until UltraMegaSquirt is released, that is. :)
BMWJustin
Post by BMWJustin »
I keep of forgetting how sweet a jet black e24 can look. I'l trying to picture my project 6er (not done yet), It will look a little like that without the gold, same front spoiler, and a full metal wide body kit. I cannot wait until the spring.
Justin
