So here's a few picts of the completed engine bay of the S38 B38 engine swap on Rob's car:
Large photos included for detail!
-Chris
Well, WE did the swap in 4 days. And we used the E28 535 radiator, plugged the original overflow, and used the M5 single temp switch for the aux fan (80/88 deg), and used the remaining port on the radiator for the relocated overflow. The lower rad hose and upper rad hose are E34 units. Altho the lower rad hose was cut short a tad.Eddie in TO wrote:hmmm, that's juicy.
Would you know if he used the E28 radiator and plugged the LH side outlet?
It appears that's what he did and relocated the coolant reservoir.
Thanks.
Rob will only give you a ride if you play nicely and agree with my politics.BDK wrote:Where did all the purple go?![]()
Looks great Chris,
I bet you and Rob are very happy with the outcome...
Good Job guys...![]()
I still want a ride in that beast!!
Indeed:Scottinva wrote:That engine is just so serious looking. To me it just screams I mean business.
Excellent write upcgraff wrote:Rob will only give you a ride if you play nicely and agree with my politics.BDK wrote:Where did all the purple go?![]()
Looks great Chris,
I still want a ride in that beast!!j/k
Here's a link to the DRAFT of the write-up.
http://www.m535i.org/officers/ra/38.html
We're still in process of finishing it up. Yes, we know it's taking a long time...don't remind us...
-Chris
awesome. Me personally, i just wanna make sure it runs great with no worries. Definitely will shoot you guys an email about this. B36 should be a bit easier than the B38 right?m535is wrote:Advice. Lots of Planning! Determine if you want to make it look like and E28 M5 with just a 3.6L motor, or make it look like a 3.6L E34 test mule. The concept behind the 3.8L was to make it look like a BMW or Hartge test mule. Either way you decide let Chris and I know and we should be able to help with any questions you might have.
The tank was updated and superceded. You cannot get the 'early' tank anymore. It's now the same PN as all B36s and B38s. So no, you don't need that additional breather tube on the tank itself. In any case, it makes no sense if you have a working 2 bar pressure cap - and it's not shown on the ETK. Nor are any connections to it. So not worried whatsoever there.wkohler wrote:It's my understanding that later cars didn't have that. I've only seen that valve on '91s here in the US.
how come you guys didnt want to use the tank that comes in the e34 setup? are you guys running the stock aux fan with the fan switch or something different? also i'm just assuming that you guys rewired it over at the fuse box so it doesnt melt the original fuse?m535is wrote:Chris is correct on that one. In addition we decided to run the E28 M5 radiator cap with the 1.4 bar pressure. This allows for almost the same cooling capacity without having to worry about damaging the e28 cooling system components. The car actually runs really cool right now even in the 100+ SC heat. Along with this we are runing the E36 fan switch on the side of the rad so the low speed of the aux fan comes on at 80 C or as soon as the thermostat opens. This gives us a really good starting point.
Good solution. I used everything from the e34 M5 to be on the safe side.m535is wrote:Chris is correct on that one. In addition we decided to run the E28 M5 radiator cap with the 1.4 bar pressure. This allows for almost the same cooling capacity without having to worry about damaging the e28 cooling system components. The car actually runs really cool right now even in the 100+ SC heat. Along with this we are runing the E36 fan switch on the side of the rad so the low speed of the aux fan comes on at 80 C or as soon as the thermostat opens. This gives us a really good starting point.
Never seen an e34 M5 without the valve. (I live in the UK)wkohler wrote:It's my understanding that later cars didn't have that. I've only seen that valve on '91s here in the US.
