Hummmm...32 valve Ford 347.
Very intriguing. 4 valve heads for a Ford Small Block. Can use stock roller cam, lifters, push rods, intake and exhaust. At $5K a set, it would be very expensive for the additional HP. Who knows…..some day.
Made by a small shop in CA - http://www.araoengineering.com/Ford/frdsmb.htm
Those rocker arms are massive -- probably pretty heavy. I'm sure the pushrod has to be excessively beefy, as do the camshaft & lifters. Not a fan.
Shawn D. wrote:Those rocker arms are massive -- probably pretty heavy. I'm sure the pushrod has to be excessively beefy, as do the camshaft & lifters. Not a fan.
From their web site - "RPM Range - The unique valve gear arrangement made possible by Arao Performance's patented head design(US Patent #5,007,387) allows rev's to over 9000 RPM without use of exotic valve train parts or freakish valve spring loadings."
I agree that they are big.
Shawn, they also make 4 valve heads for Chebby.
Snakeyestx
Post by Snakeyestx »
What ever happened to the Coates Rotary valve heads for Ford engines?
I recall seeing an article a while back about one that could turn a 5.0 14,700 rpm :shock:
Post by slammin_e28 »
^^^I like that!^^^
Snakeyestx wrote:What ever happened to the Coates Rotary valve heads for Ford engines?
A quick internet search reveals that the company died years ago along with the idea.
Compression sealing of the rotary valves is likely an issue. I thought about that years ago when I was in school not knowing that it had already been done (hasn't everything?)
Incidentally, a quick internet search reveals their website, which is current.
http://www.coatesengine.com
Your search was too quick, although it seems they've taken their patents/products out of the automotive game and into power generators. Oh, and they've merged with some Chinese company, too.
Jeremy wrote: although it seems they've taken their patents/products out of the automotive game and into power generators. Oh, and they've merged with some Chinese company, too.
Which means the idea is dead for automotive use.
Duke wrote:Which means the idea is dead for automotive use.
Not to pick nits, but the idea being dead for automotive applications is a far cry from the company itself being dead.
Damn Duke, can't you just admit you were mistaken?
Applications are available for cars, buses, trucks, trains, ships, boats, motorcycles, military uses, farm machinery, off road vehicles and numerous categories of racing. Cars, bikes, boats, home generators, industrial generators, and more.
mooseheadm5 wrote: Damn dude, can't you just admit you were mistaken?
I was wrong once.........I then discovered I was mistaken about it. :cool:
scootermcfly
Post by scootermcfly »
Ha, I didn't read this thread until now. Thanks for the link. I saw these heads on a Nelson engine video a while back. They may be heavy but the performance gains are well worth it. I'd take these heads at twice their weight. I also consider them cheap if you're building an all-out street rod like some of the stuff you see on NRE's website.
Not necessarily. It's amazing how technologies once abandoned for more conventional and time-tested ones return after a while and become popular. It might just be waiting in the wings for advancements in other fields to catch up to make this a more viable option. Time will tell.
