Page 79 of 89
Posted: Nov 27, 2019 12:16 AM
by a
I have transplanted a 528e battery and cables into the Rat my '94 Ranger 4x4. . Previously I have re-purposed nuts and bolts. too. Far as I can tell, the wrassen frassen fuel pump died. Symptoms are : no fuel, carb cleaner in the intake instantly starts engine , but dies in a few seconds. The bed has to be pushed back to service the intank pump and stuff. Haz ground and end to end continuity from the relay socket to the tank top. The relay is a regular mini relay with an 87a and an 87b 5 blades on the relay. metered out stuff jumped 12 volts to pump, no noise, nothing. Luckily, I had had the bed off when I fixed the rotten frame rail. Once I shifted the bed , I now have access to the wiring plug. I plan to to insert an E 28 main pump into the fuel line between the tank outlet and the filter . If this works, great !. If not, there's always plan B. :laugh:
Posted: Nov 27, 2019 9:51 AM
by gadget73
probably not going to suck through the dead pump. Just pop the plate off the tank and put a proper fuel pump in there. You'll spend less time dicking with it. OE was probably a Bosch pump, so might be the same as an in-tank BMW pump anyway. Change the filler neck seal too, if its typical Ford its the same one they used on everything for 40 years. Should be under 10 bucks.
Posted: Dec 06, 2019 3:56 AM
by LarryM
My 20 y/o daughter saved up money from her part-time job driving a bus, and recently asked me to find her a good used car. She goes to school 400 miles away and my goal was to find her something safe, reliable, and not too fast. I succeeded on 2 out of those 3 counts.
I added some $$$ to the fund and bought a very nice black 2009 Toyota Venza for $9500. For those of who who aren't familiar with them, the Venza was considered a crossover vehicle, based on the Camry. It was produced from 2009-2015. I really can't figure out why they dropped it; I see quite a few here in CA and there seems to be almost a cult-like following among current owners. It has a 5-star crash rating and, being Camry-based, has a reputation for great reliability. They came in either a 2.7 liter 4 cylinder or a 3.5 liter V6. I bought the V6.
It's a little quicker than I'd prefer her to have, but the V6 is a terrific engine; it was also used in the same-era Lexus ES350/RX350, among others. With DOHC, 24 valve, 268HP/246TQ and a 6-speed automatic, it's very responsive. The Venza is also a sporty car; it has a firm ride and wears 20" wheels with 50-series tires. For a crossover, it handles pretty well. The JBL-based stereo is a nice addition.
Right now I'm in the process of base-lining the maintenance: tranny/coolant/brake fluid flushes, oil/filter, air filter, cabin filter (the old one was filthy), etc. She'll be home from school next week and once she starts driving it, I probably won't get her to stop long enough to do anything else. The reality is, I wouldn't mind keeping this one for myself so I have to keep reminding myself that it's HER car!
Posted: Feb 14, 2020 12:26 AM
by amagansa
Finally sold my e39 on Sunday! I was done with it; I had severed my emotional ties to it after the thermostat debacle. Went to a younger guy and it will be his "first manual" to go along with his FR-S. Have fun.
With that money, I bought a '95 Mitsubishi Mighty Max today. Desperately needed a hauler/garbage run truck. Probably needs another 1000 in parts but I think I can make it run pretty good after some time. Good news is, it passed smog first try(my e34 took 4 tries).
Posted: Feb 17, 2020 7:57 AM
by gadget73
found that my block heater wasn't working. Cord was unplugged at the block end. Fixed that. Last week I put a power steering pump on it. Got tired of the leak. Attempted to rebuild the original first, somehow failed in that. No idea why, but it won't pump. Took it apart, verified I had everything right according to the manual, no dice.
Posted: Mar 07, 2020 1:01 AM
Score! Bought a fuel pump for the E36, just because, since it has ~225K on it now. Listed as Bosch on Amazon, hoped I'd at least get a made in China Bosch, not just a counterfeit, but the well worn box says Bosch, Made in Germany! Looks like a nice NOS score.
Then on to E39 blues. Replacing the ribbon cable for what, the 3rd or 4th or 5th time now, I managed to lose a screw that holds it together. The display that fails. So I ended up destroying an E39 cluster at P and P for 2 little tiny screws. :oops: I felt bad, but not bad enough not to do it. At least there were several other clusters for harvesting. One, lone E28. An Eta. Sniff, sniff. :( E39 530s were the most interesting cars there. :roll:
Posted: Mar 22, 2020 8:54 PM
by RonW
Replaced the Final Stage Unit for the blower in my E46. This is a common problem in these cars. It serves the same purpose as the blower resistors in the E28, but it's fancy and electronic, which means when it fails (which is often) it can do so in a way that drains the battery when the car is off. You have to be something of a contortionist to replace it.
Posted: Mar 22, 2020 9:58 PM
by John in VA
RonW wrote:Replaced the Final Stage Unit for the blower in my E46. You have to be something of a contortionist to replace it.
E39 FSR isn't much fun either, but the floorboard is a bit larger!
Posted: Mar 23, 2020 12:16 AM
Funny you guys are bringing this up, I just did the E36 last week. Easy 15 minute job. My ass. Not the job from hell, but no 15 minutes either. I think my E28 subframe bushings took less time. Actually I was almost disappointment in them, I was expecting a major fight and it was just work.
Posted: Mar 23, 2020 11:55 AM
by gadget73
Ordered some parts and manuals. Found an NOS AC compressor and a couple of the less commonly seen OE manuals for reasonable prices. I don't mind hoarding literature, sooner or later it comes in handy.
Posted: Mar 23, 2020 1:34 PM
by austin8753
Been working on my red s50 powered e30 since work has been 10/10 dead.
Installed:
e30 m3 front suspension with ground control coilovers and koni struts, race camber plates, sway bar links
new pads/rotors
new control arms, tie rods, bushes
powder coated and rebuilt calipers
all new power steering hoses (since i was there)
Also figured it was a good time to install the e30 m3 cluster and the oil temp sender, oil pressure sender, water temp sender and a volt meter gauge. Stuff I've wanted to do for the better part of a decade but never made time for. Will be likely finishing that up today.
Posted: Mar 23, 2020 2:42 PM
by rodpaine
Just completed 3,000 miles of back roads running on our new 2019 Audi RS 3 Sedan 7-speed, which we bought at the end of January 2020 and really enjoying having another German car in our garage since our E28 has been long gone to its current owner in Atlanta.
The Audi RS 3 didn't replace our 2015 Golf R, but it did replace our 2017 VW Tiguan SUV which was really a poor choice on my part. Love the Audi RS 3 and its very potent performance, on all the back roads we ran for 25 years in our E28.
-Rod
Posted: Mar 27, 2020 11:07 AM
by RDAvena
A couple of months back the alpinweiß X5 was totaled and we found a new one. Cabin fever has led to baselining the new 2012 35d(79k miles):
New vacuum hose all around with all solenoids. All hoses were extra crispy.
new filters (engine, cabin, recirc,)
Intake manifold gaskets and intake manifold CBU cleaning
Glow plugs and module
Mann Provent install to prevent some of the CBU
Charge hoses cleaned and new seals applied
intercooler inside washed and cleaned of oil
water pump, thermostat, transmission thermostat, water connection at block replaced- found it weeping when the intake manifold was removed.
fluidampr and alternator pulley installed
new drive belts
brake fluid flushed/changed
Pending:
oil change due in 500 miles
Transmission kit - fluid, filter, and mechatronic seals
3.15 differential change(front and rear) and the transfer case fluid change.
Parts had been slowly collecting for the old X5 but as stated that one was totaled so the new one is getting the benefit.
Posted: Mar 30, 2020 8:44 AM
by gadget73
fiddled with the throttle valve cable adjustment. Ford AOD is pretty much like the 4HP22, uses a cable connected to the throttle linkage to control pressure and shift points. Not sure how much is wear, how much is crap factory adjustment, and how much is cable stretch but after a lot of years it shifts early and mushy. Overdrive at 32 mph with a very sloppy engagement and its real sluggish to downshift. I'm now at full pressure at full throttle. Overdrive comes in at 40 and actually engages rather than taking a full second to finally get there and when I apply throttle it kicks down a gear. Trans has 233k well maintained miles, but its still a lot. Also swapped the air intake tube from the "non-HO" engine. 75mm end to end. The HO one has a choke point down to about 40mm, and it has a 60mm throttle body. Its meant to make the engine quieter at full throttle but audibly its very little difference. I'd rather have the airflow, it can't possibly hurt engine performance.
Posted: Apr 01, 2020 8:15 AM
by rodpaine
A few possible springles today but otherwise simply cloudy. Will make some runs on W VA backroads in our Audi RS 3, now with 3500 miles on it since late January purchase.
Still very impressed with this vehicle and very happy with our purchase, driving these country back road runs that we spent 33 years driving in our 1983 BMW E28, that I put so much work into over those years. But this RS 3 certainly puts much bigger grins on this old face.
Truly a great machine and certainly happy with it so far. Big difference in its 7-speed DSG, versus our 2015 Golf R 6-speed DSG, in that it shifts much faster than the Golf R and is much quieter in doing so. Significant improvements in the VW/Audi DSG over the years are certainly evident. And the RS 3 massive brakes certainly deliver much greater stopping power then the R, but the R is still a keeper of course. Too bad I can no longer work on these vehicles like I did on the BMW. No documentation and very different mechanicals involved on these vehicles, versus our ealier E28. Plus simply getting to old to 'wrech' on these machines. ;-)
-Rod
Posted: Apr 05, 2020 9:08 PM
:wave:
Drove ElJeepO back from FredNeck Acres.
Posted: Apr 07, 2020 4:07 AM
by Das_Prachtstrasse
I spent a bit of time on the e12. Fixed the flat spot at part throttle by removing some material from the AFM door. The bearings have worn and it was contacting the housing mid sweep. The car runs brilliantly now, so much so that on the victory drive I snapped 2nd and axle tramped so hard the exhaust broke all it’s rubber hangers and snapped off just before the resonator. It is a great car though. The more I get to know it the more I love it.
Not going to love sourcing a new exhaust though..
Posted: Apr 07, 2020 10:16 AM
Das_Prachtstrasse wrote:I spent a bit of time on the e12. Fixed the flat spot at part throttle by removing some material from the AFM door. The bearings have worn and it was contacting the housing mid sweep. The car runs brilliantly now, so much so that on the victory drive I snapped 2nd and axle tramped so hard the exhaust broke all it’s rubber hangers and snapped off just before the resonator. It is a great car though. The more I get to know it the more I love it.
:laugh: Gotta luv dat powa!!! :laugh:
Posted: Apr 07, 2020 7:52 PM
by RonW
Got my 4th generation iPod to work through my 325Ci's Business CD with a Dice iPod interface. Am I cool now?
Posted: Apr 07, 2020 7:57 PM
RonW wrote:Got my 4th generation iPod to work through my 325Ci's Business CD with a Dice iPod interface. Am I cool now?
Not cool, way cool. :bow:
I've thought about trying to get the aux input to work on the wife's E39, it's a replacement stereo that is supposed to have that capability, but it's her car and she's not really interested in it. Which makes it real easy to ignore. :D
Posted: Apr 08, 2020 5:13 PM
by John in VA
Mike W. wrote:I've thought about trying to get the aux input to work on the wife's E39, it's a replacement stereo that is supposed to have that capability, but it's her car and she's not really interested in it. Which makes it real easy to ignore. :D
I added the factory AUX kit to my 05/2003 530i prior to the beach trip last summer. Easy, if I could do it! You have to move a pair of wires/pins to the replacement connector. All set now with AM, FM, in-dash CD, trunk CD changer & AUX to run my long adapter iPod Touch (5 days worth of tunes on it).
Posted: Apr 09, 2020 8:11 PM
by Fedaykin528e
The 633 is now sitting on the street sans-injectors while they're serviced by Rich at Cruzin' Performance. Thought I could just swap in some B34 injectors, and quickly learned that that is ill advised. So, there she sits.
Posted: Apr 09, 2020 11:42 PM
Fedaykin528e wrote:The 633 is now sitting on the street sans-injectors while they're serviced by Rich at Cruzin' Performance. Thought I could just swap in some B34 injectors, and quickly learned that that is ill advised. So, there she sits.
Aside from the fact that it would probably barely run due to different flow rates, that's actually ok. That ECU doesn't care if the injectors are high impedance (resistance), it's when you go lower and increase current draw it's a problem.
Posted: Apr 10, 2020 9:23 AM
by RoyW
Itching to do something with the "other" cars, or even the e28.... but, the virus has curtailed everything. Can't get the plates and reg for the '02 (DMV is closed); can't work on the '02 as it's at shop and lock in; can't get two cars that are in storage in NH (they're closed), can get at the two cars that are in my garage here in NY, and so I put the NY plates on them the other day (that I got in Jan before heading to FL), but they are not inspected yet (need stickers)... so, been doing a little extra detailing :) Boring!! Need to, want to, must DRIVE!!! :)
Hoping things will improve for the country and some degree of normalcy will return soon... maybe May?? Meanwhile, hope you are all safe and healthy. Bless you.
-RoyW
Posted: Apr 13, 2020 1:19 PM
by gadget73
When I bought my Mark VII I was told the evaporator in the dash was bad. Came with new parts. I started to prep for dash removal to change it before I realized I hadn't actually confirmed the diagnosis. Pulled vacuum and it held overnight. Charged it with propane and I'll see if the interior stinks in a few days.
Posted: Apr 13, 2020 5:20 PM
gadget73 wrote:When I bought my Mark VII I was told the evaporator in the dash was bad. Came with new parts. I started to prep for dash removal to change it before I realized I hadn't actually confirmed the diagnosis. Pulled vacuum and it held overnight. Charged it with propane and I'll see if the interior stinks in a few days.
Hope you're not, or don't have passengers who are :pimp: .
Posted: Apr 14, 2020 8:26 AM
by gadget73
it has been and shall remain a non-smoking car, and not just because of the explodo-mix in the AC system :)
Posted: Apr 17, 2020 9:08 AM
by gadget73
new window channel felts in the Continental. Originals had gone rock hard and shattered, leaving a gap in the rear window right near my ear. The whistle was very annoying. When your leaky window seals make more whine than the turbo does, its time to fix that.
Posted: Apr 20, 2020 6:36 PM
by Fedaykin528e
Dropped a pintle cap down the intake. :brickwall:
Posted: Apr 20, 2020 10:56 PM
by RetiredDoc
Since staying at home and now into my seventh week, none of my vehicles have been driven during that time. Today I hooked up my stock of Battery Tenders to the 3 of the 6 of them that were not already connected. That meant pirating the battery maintainers from my tractor, my equipment trailer winch, and my house generator batteries.
As the lock down continues I’ll need to work out a rotation schedule for all the batteries to keep them maintained, or order a few more maintainers on Amazon.
Checked with my auto insurance company about a discount because of no driving and they offered a 15 percent rebate of premiums for the past 2 months.
