Dates
AKM5
Dates
Post by AKM5 »
When I am on site, the dates for all posts etc. seem to be "stuck" on 05/15 (the day I joined) whats up?
AKM5
That isn't happening for me.
Are you sure you're you're not looking at your own posts and noting the "Joined" date to the left instead of the "Posted" date at the top of each post?
What do you see for "Last Post" dates on each sub-forum?
AKM5
Dates
Post by AKM5 »
Every date is 05/15/2009, even the response to my post. all rt hand column summaries list last post as 05/15/2009. Do I have some system abled or disabled?
Re: Dates
AKM5 wrote:Do I have some system abled or disabled?
There's no "system" or setting to make all of the dates the same, especially for just one user. Maybe Justin will chime in with a theory...
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
The reason is because you over rode the date function in the user profile with 5/15/2009.
You would probably want to use "n/j/Y g:i A" if you want the date format with slashes and time display. If that isn't what you want, let me know how you want it to look and I can change your profile to the proper PHP date syntax.
AKM5
Dates
Post by AKM5 »
Thanks, that "fixed it" :oops:
