WTB: Fuzzy Body seals for door frame
Posted: Oct 15, 2010 12:02 PM
by bac914
Seeking all four fuzzy door seals that sit on the frame, but front are priority.
Thanks,
Brian.
Re: WTB: Door Seals and Rear Bumper Pad
Posted: Oct 15, 2010 12:22 PM
by lmc337
The "mouse fur" or the seal on the actual door - i should have all 4 of the ones on the door, and do have a rear bumper pad (Impact Strip).
Let me know, and i can get it all pulled this weekend to ship Monday.
Lee
Posted: Oct 16, 2010 9:51 AM
by bac914
I meant the stuff on the frame, not the door, so yes the mouse fur. Is that seal and the mouse fur a separate piece or does it come as one? Was assuming it's all one. That's what I need.
Can you pm me a pic and price/shipping/80123 of the bumper pad?
Thanks,
Brian.
Door seals
Posted: Oct 16, 2010 10:01 AM
by truckerwillie
If other poster has not bought, I need both right side rubber seals.
1986 535i.
truckerwillie70@yahoo.com
Posted: Oct 16, 2010 7:33 PM
by lmc337
PMd OP
Door rubber, right, on the door, not the chassis mouse fur? And right as in passenger side? (always helps to be sure)
Door seals
Posted: Oct 17, 2010 9:48 PM
by truckerwillie
It is the seal (mouse fur?) attached to the body. I see now that thr rubber seal is attached to the mouse fur. I need both RS (passenger) front & rear. My car is black inside if that matters.
Re: Door seals
Posted: Oct 17, 2010 10:01 PM
by lmc337
truckerwillie wrote:It is the seal (mouse fur?) attached to the body. I see now that thr rubber seal is attached to the mouse fur. I need both RS (passenger) front & rear. My car is black inside if that matters.
doesn't matter, as I stated above, I have the seals on the door, not the frame. Good luck hunting.
Door seals
Posted: Oct 17, 2010 10:21 PM
by truckerwillie
Thanks for your help.
Truckerwillie
Posted: Oct 19, 2010 11:22 AM
by 87royal
Who still needs this? Going to check the condition of the spare set I have.
Posted: Oct 19, 2010 11:41 AM
by My E 28 533i
I need them too.
door seals
Posted: Oct 19, 2010 12:32 PM
by truckerwillie
I need psgr side front and rear, if available.
truckerwillie
1986 535i
Posted: Oct 19, 2010 12:43 PM
by bac914
I'm still looking for a good bumper pad and the "inner" door seals, the ones on the frame with the mouse fur.
Thanks,
Brian.
WTB Fuzzy body seals for door frams and bumper pad
Posted: Oct 19, 2010 4:31 PM
by bac914
Updating subject as it appears I didn't state this correctly and I may not be catching the right folks' eye.
Looking for the fuzzy seals for the door frames and a good condition bumper pad.
Thanks,
Brian.
Posted: Oct 19, 2010 7:06 PM
by GaAlpinaOwner
What the heck part number is this? Are we talking about this?
http://www.realoem.com/bmw/showparts.do ... g=51&fg=55
parts 1&2?
Posted: Oct 19, 2010 8:01 PM
by bac914
Yes that's the stuff. 51721904328 and 9.
Thanks I couldn't find it in the catalog.
I see that several of us need this stuff.
Posted: Oct 22, 2010 2:56 PM
by GaAlpinaOwner
I suggest everyone go put these on B/O with a dealer. This is the only way they will make more. I did
Posted: Oct 22, 2010 3:28 PM
by lmc337
PM'd Brian to advise of the 'need' - official response below:
Parts Dept wrote:They have been on backorder since June. We play the waiting game.
Posted: Oct 23, 2010 9:54 PM
by jwhiii
The RealOEM diagram is confusing. Item 1 points to the Driver's side front and passenger's side rear. Item 2 points to the Passenger's Front and Driver's rear. It is the same on Max Imports. Is this an error?
Also, these are some high dollar parts due to limited availability. Almost a thousand bucks for all four! Anyone find any alternatives, my fronts are pretty ratty.
Posted: Oct 23, 2010 11:39 PM
by John in VA
jwhiii wrote:The RealOEM diagram is confusing. Item 1 points to the Driver's side front and passenger's side rear. Item 2 points to the Passenger's Front and Driver's rear. It is the same on Max Imports. Is this an error?
No, that's correct. That makes the fuzzy bit be on the inside.
The Fussies
Posted: Oct 24, 2010 2:12 AM
by yomenendez
Just had to pull my fussies off the rubber edge...faded,torn and rotten after 22 years. The way I look at it....it is just more of BMW Shadowline Trim to look at...especially if your interior is black...the only really unsightly view is at the bottom of the B pillar...Good Luck
Posted: Mar 01, 2011 4:46 PM
by bac914
still looking for these if anyone is parting out a car and has some....otherwise still waiting for the parts guy to hook us all up....
Thanks,
Brian.
Posted: Mar 01, 2011 4:54 PM
by Parts Dept
I check the order just about every day to see the status. They are still on the order list but no ETA yet. (sigh)
Posted: Mar 01, 2011 6:51 PM
by ElGuappo
I generally pull the mouse fur off, looks better without it.
Just a clean blakc rubber edge.
Heres a thought too: The e23 door surrounds work on the E28, and they go ALL the way around the door to seal it. You just have to modify the sill piece.
Posted: Mar 01, 2011 7:48 PM
by stuartinmn
Parts Dept wrote:I check the order just about every day to see the status. They are still on the order list but no ETA yet. (sigh)
I'm guessing they'll finally cough up a few sets in about the year 2050, when none of us care anymore. :)
Posted: Mar 03, 2011 11:43 PM
by gmb49all
I have a set, PM me for a price...
