M5 Caliper Oring source
FirstFives Dictator
Post by FirstFives Dictator »
Disclosure: this is actually for an e12 application. ~_~
I wouldn't normally split calipers but this is a modification to use larger spacers (e23).
Does anyone have a good source for the 4 o-rings that go in the 4-pot Ate calipers?
cgraff
Post by cgraff »
I believe BMP had sourced some especially for the older 2 and 4 piston calipers, but this was a few years ago. You could try them.
-Chris
Walt
Post by Walt »
Carl Nelson had some made. La Jolla Independent.
Chris, you have some!
Walt
Philo
Post by Philo »
All brake caliper rebuilders have them..., call Centric Brake in Los Angeles. tell them what your doing and they should be able to pull an application cart and help you out. Ask for Graem or Jason.
310-218-1082
