Big boost half shafts/axel help
LinneBro
Post by LinneBro »
I am swapping an turbo s52b30 into my 533i and I'm going to be making north of 700whp. I know my half shafts will break. I was wondering what you guys did about yours. I hear people cryogenically treating theirs and then I was looking a chromolly half shafts from driveshaftshop.com. I also head the euro 524td ran stonger half shafts. What do you guys recommend?
T_C_D
Re: Big boost half shafts/axel help
Post by T_C_D »
No 700whp cars here.
Cactus
Post by Cactus »
Cryogenic treating probably isn't going to do much for you. You're better off buying custom ones.
That's an ambitious power goal for an e28 chassis.
LinneBro
Post by LinneBro »
My friend was making over 700 in his e30. I am going to be doing some reinforcing before I do anything crazy in her.
LinneBro
Post by LinneBro »
Do you guys know if the half shafts on the euro 524td are thicker or more re-enforced that my 533i? or maybe any axels that will be a direct fit?
smhheidari
Post by smhheidari »
For that much power i would go with entire E32 750i subframe with the 210 diff.
you might need flares (depends on wheel offset) because of the wider wheel base.
LinneBro
Post by LinneBro »
Il look into that. I do wonder how much wider they are! thanks!
howelll
Post by howelll »
Many high power e30 guys use the z3m half shafts, very expensive and hard to come by. The driveshaft shop may be able to make some custom axles for you.
T_C_D
Post by T_C_D »
You should probably make 700rwhp and then have enough traction to break the stock axles/diff before upgrading. I have managed 1.6x 60ft times in my e28 which puts more tq to the ground than anyone else to my knowledge in the USA and have never broken anything. It's the application of the power that breaks or doesn't break parts. You can shatter a diff with 200rwhp if you wheel hop the drivetrain to death. You won't break anything doing 3rd gear hwy burnouts with your 700rwhp.
Yes, 188mm diff too. 1.58 60ft in 188mm diff in an e34.
T_C_D
Post by T_C_D »
LinneBro wrote:Do you guys know if the half shafts on the euro 524td are thicker or more re-enforced that my 533i? or maybe any axels that will be a direct fit?
E28 shafts are solid.
LinneBro
Post by LinneBro »
After much research I just ended out getting a partial sponsorship and got some CAtuned chromolly halfshafts Im pretty sure they are made by driveshaftshop.
M. Holtmeier
Post by M. Holtmeier »
Nice! Let us know how they hold up.
